10-31-2012, 14:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | Qtek 9000 Resurrect Resurrection succes, but i can not enter download mode, or boot mode to be able to flash it. Cannot power on eather, connected on USB, red light always ON. What i need to do ? am i wrong with something ? Code: Selected Resurrector: [Qtek 9000 G3 V1.00] Connecting to the dead body...OK Set I/O Voltage reads as 3.01V, TCK Frequency is 10 MHz Detected dead body ID: 0x79265013 Resetting target...OK STATUS: Target is halted. R0 = 0x00000000 R6 = 0x3EE92BBF R12 = 0x53EFEFE6 R1 = 0xF6BFDEFF R7 = 0x255F29D7 R13 = 0xBFFDFFDF R2 = 0x7A67FE6C R8 = 0x1BFE76FF R14 = 0x00000000 R3 = 0xBA77FFEF R9 = 0xFEADE5BF R15 = 0x00000000 R4 = 0x7F7FCDDE R10 = 0xE7EBF3FF CPSR = 0xF80000D3 R5 = 0xAFF7DDEC R11 = 0xEFAFF5EF Connecting to the dead body...OK Detected dead body ID: 0x79265013 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 10 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0200/0xFDFF (32MB) Detected an Initialized FLASH2 Chip, ID: 0x0200/0xFDFF (32MB) Flashing the dead body...OK Resurrection complete! |
10-31-2012, 15:41 | #2 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | From "Resurrection Help": Quote:
10-31-2012, 18:24 | #3 (permalink) |
Member: 1671934 Status: Offline Thanks Meter: 247 | I used WAY1: Writing SPL code directly into the MDOC memory (there are 2 hardware versions of the Qtek 9000 exist: boards with G4-type MDOC memory and boards with G3-type MDOC memory; current resurrector contains DCC Loader for G3 MDOC memory; thus for G4 version you need to use other resurrector) WAY2 doesn work, gives error. Battery was 3.9v |
