01-18-2013, 11:00 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: romania Age: 44
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | radar unlock help how to conect it?? if i make the testpoint and conect phone, first is detected as QHUSB_DLOAD but then is detected as ZEUS FLASH DEVICE. how can i connect it corectly? |
01-18-2013, 12:29 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | "Zeus device" is because You have Sony drivers installed. You've to remove those first, and manually install original drivers from RIFF \Drivers dir. |
The Following User Says Thank You to legija For This Useful Post: |
01-18-2013, 14:04 | #3 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | me again i instaled riff on another pc that do not have zeus flasher and dtrivers installed and now phone after testpoint is detected as HS-USB Diagnostics 9008. what is wrong now? this phone is getting me crazy!! |
01-18-2013, 15:48 | #4 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You're doing something wrong then. You should carefully read sticky topic here about HTC via usb cable. |
01-18-2013, 17:41 | #5 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | now is dead i tried once more to get that RADAR detected as it should and i think i've touched with needle the capacitor near that tp resistor and now phone is not powering anymore and chip near usb connector is getting hot if i try to power phone from power switch or insert usb cable. any ideea what can be done?? how can i fix it!!! please help me!!! |
01-18-2013, 22:32 | #6 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Check Resistor for broken or maybe contact with another place.. ------ About TP: You Need Install Driver for 2 Times: First: After Device Manager Deteted as HS-USB Diagnostics 9008,install driver from RIFF Directory Then Press Resurrect... Quote:
06-14-2013, 19:34 | #7 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 327489 Status: Offline Thanks Meter: 56 | Htc radar pi06100 testpoint please Quote:
there is an picture for easyli edition Thanks in advance | |
06-16-2013, 02:20 | #9 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | Friend drivers are on the road you indicate tested by me for the test point connect the test point and finally after usb stack qye after that and installed this driver can do wonders http://forum.gsmhosting.com/vbb/f634...a-usb-1529772/ |
