08-20-2014, 22:50 | #3 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | i have one too, after ressurection stil dead , no download mode. this is log : pen serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (000000, 0x000200000000 Bytes = 8.00 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (000000, 0x000000100000 Bytes = 1.00 MB) No Resurrection Data is available for the eMMC Chip with Capacity = 8.00GB WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! |
03-14-2015, 15:29 | #4 (permalink) |
Freak Poster Join Date: Jul 2008 Location: india
Member: 816244 Status: Offline Sonork: 100.1626537 Thanks Meter: 91 | i have same problem with n7000 for Resurrection Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung N7000 V1.0.4860.58267] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! WARNING: Embedded I/O Voltage is overriden to 3.10V Set I/O Voltage reads as 3.07V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! FOR Dump Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung N7000 V1.0.4860.58267] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! WARNING: Embedded I/O Voltage is overriden to 3.10V Set I/O Voltage reads as 3.07V, TCK Frequency is 8 MHz Settings Code: 0x20010B00000000400000000001400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Writting FLASH1 memory from 0x000000400000 to 0x0000017FFFFF Completed in 00:04:00.679 (Average Transfer Rate: 85.09 kB/s) But phone cant go on download mode... and phone detect with " SEC SOC SMDK Board " Need Solution... |
