Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 01-01-2013, 10:30   #1 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: 100.1650339[OFFLINE]
Thanks Meter: 987
Arrow reliance samsung b229 blinking problam
how to flashing for riff box pinout need
wbr ; tejaram
Old 01-01-2013, 11:26   #2 (permalink)
M0YAL's Avatar
Member: 1583254
Sonork: 100.1602320
Thanks Meter: 4,770
http://forum.gsmhosting.com/vbb/f634...-want-1572131/
The Following User Says Thank You to M0YAL For This Useful Post:
Old 01-01-2013, 11:48   #3 (permalink)
Member: 1681461
Thanks Meter: 987
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.34, JTAG Manager Version: 1.48
Selected Resurrector: [Samsung B219 V1.0.4443.4197]
Connecting to the dead body...OK
Set I/O Voltage reads as 2.59V, TCK Frequency is 5 kHz
Detected dead body ID: 0x122CE0E1
Detected dead body ID: 0x122CE0E1 - CORRECT!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x76010000000000000000000000800000
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...FAILED
ERROR: Wrong response code from the RIFF Box: 0x45
The Following User Says Thank You to .::TEJARAM::. For This Useful Post:
Old 01-01-2013, 13:30   #4 (permalink)
M0YAL's Avatar
Member: 1583254
Sonork: 100.1602320
Thanks Meter: 4,770
Please Check Nrst Pin Conntection
Old 01-01-2013, 13:37   #5 (permalink)
Member: 1681461
Thanks Meter: 987
Detected dead body ID: 0x122CE0E1 - IGNORED!
Settings Code: 0x3E0100000000000000000000007FFFFF
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...FAILED
ERROR: RAM memory selftest failed.
Old 01-01-2013, 19:02   #6 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Thanks Meter: 756
try with lower speed and if still not working then open direct access to jtag programing select qsc1100 set speed to 1mhz and try it will surely give error, disconnect and again reconnect and continue writing follow the same process till the time it is completed to 100%
Old 01-03-2013, 15:02   #7 (permalink)
Member: 1681461
Thanks Meter: 987
thanks all bor my porblam is ok by riff
WBR ; tejaram
Old 01-12-2013, 06:53   #8 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 222
WBR ; tejaram
plz share the riff box screenshots or process & also send the working dump file link.....
Old 01-12-2013, 07:10   #9 (permalink)
M0YAL's Avatar
Member: 1583254
Sonork: 100.1602320
Thanks Meter: 4,770
Please Check here
Old 01-19-2013, 08:37   #10 (permalink)
Member: 683579
Thanks Meter: 216
b229 blinking solution done by riff
thx to moyal help
The Following 2 Users Say Thank You to KIMTTeam For This Useful Post:
Old 01-19-2013, 09:34   #11 (permalink)
Member: 698592
Sonork: 100.1645954
Thanks Meter: 18
i Can't rpaird sucsss..
[QUOTE=KIMTTeam;9118244]
Selected Resurrector: [QSC1100 X14 NOR V1.0.0.0]
Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz]
Settings Code: 0x4601000E000000000000000000400000
Old 01-19-2013, 13:12   #12 (permalink)
M0YAL's Avatar
Member: 1583254
Sonork: 100.1602320
Thanks Meter: 4,770
[QUOTE=DILIP_MKPKRB;9118397]
Plz Check your Connection (Nrst Must not Connect )
Old 01-19-2013, 13:29   #13 (permalink)
Athelcute's Avatar
Member: 885719
Sonork: 100.1604802
Thanks Meter: 388
yes this error alwase getting in samsung b229
just connect using qsc1100 dll
then halt the target
now write dump
you got error "0x45" don't worry again go to jtag read/write tab and again halt the target
you see its waiting for halt now remove power and put again power in board you see halt completed
now go again in dcc read/write and write dump
this time dump start writing in it.
The Following User Says Thank You to Athelcute For This Useful Post:
Old 02-05-2013, 12:33   #14 (permalink)
Member: 1681461
Thanks Meter: 987
Arrow
Originally Posted by sharmajee10 View Post
give me flash file sir
pst and file
b229 100% ok.rar
wbr ; tejaram
Old 02-05-2013, 16:50   #15 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,215
Dear Friend
If Your Cellphone In Blinking Condition, So Please Check It's Taking Download Mode By Pressing 9+Power Keys, If Yes Then Flash By PST & Flash File.
Here It's Samsung B229 Flash File With PST : Samsung B229 pst & original flash file download here
The Following 2 Users Say Thank You to MyGSM World For This Useful Post:
Page generated in 0.63313 seconds with 7 queries
