03-10-2013, 17:16 | #1 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Ukraine Kyiv
Member: 117432 Status: Offline Thanks Meter: 6 | Repair router ZTE AC30 help ... this is log from riff Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [MSM7XXX L41 D04 NAND V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01E00E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x04000000000000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. i try differet speed but same result ... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [MSM7XXX L41 D08 NAND V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01E00E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x04000000000000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. in attach jtag pinout and readed full (by riff box) by another man. i cant contact to him ... please exsplain that is problem ... |
03-10-2013, 17:19 | #2 (permalink) |
Member: 117432 Status: Offline Thanks Meter: 6 | one man say to select huawei c8500 and log same result: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Huawei C8500 V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01E00E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
03-11-2013, 12:40 | #4 (permalink) |
Member: 117432 Status: Offline Thanks Meter: 6 | hi some progress ... ))))))) when i select "Useful Plugins" tab and select "Direct JTAG Access to Flash Memory" and activete it. select Chipset(MCU): MSM7625 than - Connect & Flash ID this is some logs: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Target: [MSM7625, 2.60V, TAP0] Connecting to the MSM7625 target...OK Detected dead body ID: 0xC01E00E1 - IGNORED! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resetting and Halting target...OK R0 = 0xA0A000B0 R6 = 0x00000002 R12 = 0x00000001 R1 = 0x0000000D R7 = 0x00000002 R13 = 0x80004570 R2 = 0x00000000 R8 = 0x00004B4F R14 = 0x80002B78 R3 = 0xB800010C R9 = 0x80004A1C R15 = 0x80003418 R4 = 0x800045D0 R10 = 0x00000000 CPSR = 0x600000D3 R5 = 0x00000004 R11 = 0x00000000 Connecting to MCU's NAND Memory Controller...OK Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x15AA (256MB) i can read flash but very slow .... about 4 hours - i have no this time.... then i close plugin and go to "DCC Read/Write" tab press read memory .... porcess of readign - fast ... this is log : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [MSM7XXX L41 D04 NAND V1.00] Connecting to the dead body...OK Detected dead body ID: 0xC01E00E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x01000000000000000000000010000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x15AA (256MB) Reading MCU address space from 0x000000000000 to 0x00000FFFFFFF ERROR: Failed to unpack received data. Terminating. but stop always on 0x000005500000 --- about 33% )) i select "DATA LENGHT": 0x000010000000 (256mB) RIFF team please help add this device (AC30) to supported .... |
