08-06-2010, 16:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: INDIA
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | [SOLVED] Sir please add s8003 |
08-07-2010, 08:10 | #4 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | sir as your instruction i tried by selecting S8000 all done well but phone is not working or not entering in download mode will you please suggest me what to do for this? i am using the box for first time , also phone is new and i opened it first time. Open serial port...OK Connecting to the RIFF Box...OK Connecting to the dead body...OK Detected dead body ID: 0x07B76F0F - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0040 Flashing the dead body...OK Resurrection complete! |
08-07-2010, 09:21 | #8 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Phone must enter boot mode now, if battery is charged. Make sure to read manual properly. If You get red LCD and "Upload data to PC" text, then there is much more damaged data. We have one user who tried repair with other tool and his phone is now stuck on this. Solution is to read full dump from working phone and write back to dead. |
The Following User Says Thank You to legija For This Useful Post: |
08-07-2010, 09:28 | #10 (permalink) | |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | Quote:
sir battery is fully charged but i will check it again by charging more . | |
08-07-2010, 09:37 | #11 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | This is how You need to set the software : First make dump from damaged phone, and save it. Then make dump from working phone, save it, and the open in Main field. Note the sampling TCK frequency - if writing fails on some %, lower down the sampling frequency until You get the result. |
08-07-2010, 10:12 | #12 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | very very sorry sir LEGIJA as you said is correct i think this is need 100% charged battery now my phone is starts but hangs on logo and also enters in download mode i will flash phone and post result thanks SIR LEGIJA for your support for my first attempt success iam very happy to work with RIFFBOX always be the best and first |
The Following User Says Thank You to sureshshetty For This Useful Post: |
08-09-2010, 06:59 | #13 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | SIR LEGIJA i need your help again because i tried this phone by flashing and after by downloader 5.65 boot also but now this is same as before starts goes on samsung logo at the bottom blue bar goes half and stops . so what to do for this?? as you said ,will the dump work for this phone for this status? or any other suggetion? Code: Count supported models - 190 Reading file... OK Model: S8003 Version: S8003JVIF1 Searching Samsung USB Flash interface... detected (COM12) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:05:02) Reading file... OK Model: S8003 Version: S8003JVIF1 Searching Samsung USB Flash interface... detected (COM12) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:05:04) ownload Start Ch[0] BootLoader 290.5KB OK[0.3s] Dbl 154.2KB OK[0.3s] All files complete[1.4s] |
08-09-2010, 11:10 | #15 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | From log i can see its not flashed by multiloader. Its flashed by some tool who's author learnt strange english somewhere. It is "Sent", and not "Sended" |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
