07-17-2011, 18:33 | #1 (permalink) |
Junior Member Join Date: Apr 2004 Age: 78
Member: 60861 Status: Offline Thanks Meter: 0 | repairing tg01 boot, pls help start JtagManager and press "Resurrection". Here is the log: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.29 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 Whatever clock speeds I try always got: Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 What this 0x45 err code means? FYI: my pc has sufficient usb power supply and wiring of jtag is checked many times. I updated Toshiba_TG01.dll updated riffbox firmware to v1.25 updated JtagManger to v1.29. This is strange as v1.29 is the lastest version after update, but I DO see screen captures of someone else's JtagManager shows v1.32 or v1.33. http://forum.gsmhosting.com/vbb/f634...pport-1043024/ also mentioned lastest version should be v1.33. Where can I get this version 1.33 of JtagManger? Or is my Riffbox broken? Many thanks... |
07-18-2011, 09:17 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, You have different HW version there, and its repairable, just need some manual work. Please first read below listed threads : http://forum.gsmhosting.com/vbb/f634...-read-1111319/ http://forum.gsmhosting.com/vbb/f634...nuals-1051474/ http://forum.gsmhosting.com/vbb/f634...pairs-1130656/ You can contact me via ICQ afterwards and I will help You to fix the phone. My ICQ UIN : 299912089 |
12-05-2011, 01:15 | #3 (permalink) |
Junior Member Join Date: Mar 2004
Member: 57329 Status: Offline Thanks Meter: 0 | I'm getting the same problem with the latest firmware and software. Log is as follows: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 Do you have any suggestions? Thanks |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
