Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 05-21-2018, 22:25   #1 (permalink)
Member: 2709215
ERROR: At least 1.49 Box's Firmware version is required
I am getting the above error message. The complete message is:
ERROR: At least 1.49 Box's Firmware version is required.
Current version is RECOVERY. Please update BOX Firmware.
Yet when I run the update, I get the following message:
Getting RIFF Box Info...OK
RIFF Box Bootcore version 2.00...OK
Connecting to the Updates Server...OK
Downloading new Firmware from Server...OK
Setting Update Mode...OK
Updating Box's Firmware...OK
Restarting box, please wait...OK
Firmware Update Completed OK
Current Firmware Version: Recovery (RIFFBOX2)
What can be done to correct this so that the box can operated? I am running Win 10 Enterprise (64-bit)
Old 05-22-2018, 10:05   #2 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
check device manager for Update Port driver which is must for firmware update
replug box create Update port ...Recovery firmware will be flashed.
br,
Old 05-22-2018, 20:10   #3 (permalink)
Member: 2709215
Thanks. Although, I am not clear on what you are saying... The RIFF Box is showing up in device manager as USB Service Device (COM9) and if I attempt to update the driver Windows tells me that is already up to date.
Old 05-22-2018, 21:22   #4 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 1,100
1. Connect RIFF BOX 2 in PC,
2. Go Device Manager,
3. Right Click on USB Service Device (COM9) & Select Manually Update Driver
I)........Select Brouse for drivers on your computer,
II).......Select the device driver you want to install for this hardware.
III)......Now here you see RIFF BOX II Firmware Update Driver, just select & Click Next
IV)......After Driver Installation successfully see in Device Manager now there
RIFF BOX II Firmware Update Port (COM9) show...
Like This...
4. Now Open JTAG Manager & Update ur Box again...
The Following User Says Thank You to Pijush Das For This Useful Post:
Old 05-22-2018, 23:21   #5 (permalink)
Member: 2709215
Thanks for the detailed information. Although, I continue to have a issue as the driver will not update. I will post screen shots in a bit once I get to my FTP computer.
Old 05-23-2018, 01:12   #6 (permalink)
Member: 2709215
After attaching the RIFF Box and stating the JTAG Manager software, it appears to be communicating properly...
When looking at Device Manager, the RIFF Box is showing as follows...
When I attempt to install the RIFF Box Firmware driver, these are current drivers I have to choose from...
Yet, whichever driver I choose I get the message and I am unable to install an updated driver...
Old 05-23-2018, 22:18   #7 (permalink)
Member: 2709215
Where can I download the Update Port Driver for Win 10? Does anyone have a link?
Old 05-24-2018, 18:33   #8 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 1,100
No Need any external Driver....
Just install official Driver from installation directory....
I already give u instroduction, just follow & do apply same method...
Again say you please Apply this process....
Old 05-29-2018, 02:31   #9 (permalink)
Member: 2709215
I have followed these steps exactly and continue to get the message stated above once I choose the RIFF box driver.
Page generated in 0.21346 seconds with 9 queries
