03-15-2015, 23:15 | #1 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1442875 Status: Offline Thanks Meter: 2 | riff box clone solution 1.50 3. - Run the application version 1.01 Jtag supporter 4 . - Press the Fix Support to redirect access to the support. 5. - Fixed support Pusla on Check to check who arranged access and will get the message in yellow letters on a website confirming that have been redirected to the support. 6. - Run the full setup of the JTAG Manager version 1.50 . 7. - Replace the JTAG Manager executable ( . Exe ) which is in this tablet that I have made above. 8. - Open the JTAG Manager and update your box firmware to 1.37 (included in the archive as well) . After completing these steps should be able to connect your riff box and access the update section where you can download the dll libraries wishing phones . As always make the respective tests and post your results for feedback . original source of the information : http://www.riffjtag.com/ orginal post RIFF Recovery cloned (procedure ) |
The Following User Says Thank You to smailo3200 For This Useful Post: |
03-15-2015, 23:49 | #2 (permalink) |
Member: 1442875 Status: Offline Thanks Meter: 2 | correction repara riff - Download - 4shared pass: riffclon 2. - Connect the cloned box . 3. - Run the application version 1.01 Jtag supporter 4 . - Press the Fix Support to redirect access to the support. 5. - Fixed support Pusla on Check to check who arranged access and will get the message in yellow letters on a website confirming that have been redirected to the support. 6. - Run the full setup of the JTAG Manager version 1.50 . 7. - Replace the JTAG Manager executable ( . Exe ) which is in this tablet that I have made ??above. 8. - Open the JTAG Manager and update your box firmware to 1.37 (included in the archive as well) . 9- add these three lines to the bottom of your host file found in C:\windows\system32\drivers\etc\host 212.124.123.206 riffbox.org 212.124.123.206 warrior.riffbox.org 212.124.123.206 runner.riffbox.org After completing these steps should be able to connect your riff box and access the update section where you can download the dll libraries wishing phones . As always make the respective tests and post your results for feedback . original source of the information : http://www.riffjtag.com/ orginal post RIFF Recovery cloned (procedure ) |
05-20-2015, 10:24 | #5 (permalink) |
No Life Poster Join Date: Dec 2008 Location: TURKEY Age: 46
Member: 917368 Status: Offline Sonork: 1615575 Thanks Meter: 147 | riff box clone solution 1.50 Connecting to the Updates Server...ERROR ERROR: Couldn't connect to the Updates Server. Try again later. Not Server Connect... |
12-23-2017, 05:31 | #6 (permalink) | |
Junior Member Join Date: Jun 2011 Location: brunei darussalam
Member: 1596479 Status: Offline Thanks Meter: 2 | does this process still works?? Quote:
