04-10-2015, 11:16 | #2 (permalink) |
Junior Member Join Date: Jul 2010 Location: Germany
Member: 1351772 Status: Offline Sonork: 100.1640819 Thanks Meter: 4 | I think this a general problem because the riffbox server seems to be down at the moment. Can't get any updates or something like that. We have to wait for a support comment |
04-12-2015, 09:12 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | No are in my shop now but if server is Busy or in maitenance at the moment if you try to Change Psw...who get response to you?...when change psw you will have received one email from server for confirmaction...now if you not has received nothingh you are blocked...try when server isn't busy or off line, (you write this not tested)... BR |
04-12-2015, 09:46 | #6 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ok, yes confirmed, server is under maintenance from 10/04/2015 and need few days...in the meantime cannot download .Dll or Package....(only on specific request can have), Above error not say: Quote:
if now you have request change of psw you must need of wait Reply from server in you email or registraction for one "Activaction Code" and if not receive this you cannot use temporary you Riff becouse you have request Change of psw.... wait for server is other time online and all will be solved... BR | |
04-12-2015, 15:48 | #10 (permalink) |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Yup Its Online Now!! Hi, Both servers are up from now on. It may take some time for DNS to propagate, if You experience any problems You can manually edit HOSTS file with following IP-s: Riff License Server: Code: 93.191.132.28 runner.riffbox.org Code: 136.243.24.91 www.riffbox.org 136.243.24.91 ftp.riffbox.org 136.243.24.91 faq.riffbox.org |
04-22-2015, 08:41 | #15 (permalink) |
Freak Poster Join Date: Oct 2011 Location: vigan, Ilocos Sur
Member: 1670761 Status: Offline Thanks Meter: 9 | I did edit the Host but still I cant connect Connecting to the Updates Server...ERROR ERROR: Couldn't connect to the Updates Server. Try again later. any other solution pls |
