08-11-2018, 13:30 | #271 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | |
The Following 4 Users Say Thank You to legija For This Useful Post: |
08-30-2018, 04:18 | #272 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF Box DLL updates, 30.08.2018 New Resurrector DLL-s today: USB:
ISP:
The Following 8 Users Say Thank You to legija For This Useful Post: |
08-30-2018, 04:22 | #273 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF Box eMMC Plugin v5.0 released -USB Qualcomm and UFS chips support eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v5.00 ------------------------------------- - added USB Connection Mode (Qualcomm Sahara) - added support for parsing EFI,PIT,MBR-type dumps from UFS memory (Page Size = 0x1000) - added option to select active Partition to be parsed - in this case "Parse Connected Memory' button will parse precisely the selected partition, and "Parse Local Dump File" button will assume that parsed dump was read from the specified partition; - [Parse Official Firmware]: Improved loading MTK partition files which are named with prefix '__NODL_' while on disk those are named without prefix. - [Parse Official Firmware]: fixed the bug when clicking the "Read Form Connected Device" button to read partition sizes during the MTK scatter file parsing did nothing. - for PIT/EFI parsed dumps/devices improved parsing when 'Show Gaps' is checked; __NOT_ALLOCATED space at the end of image file is autodetected for BACKUP_GPT partition. - added automatic select/deselct all partitions feature to context menu (right-click on partitions list, then chose desired action) - fixed the bug when plugin loaded (injected) in total more than 2GB of partitions data then reading wrong data could occur. - default chip size (which is used when expanding expandable partitions - those with size = 0) is changed flrom 64GB to 512GB - [Load Firmware Files]: fixed bug when loading firmware files from GPT partition: if "gpt_backup" file was present, the gpt_backup file was loaded into gpt partition, instead of 'gpt_main'; - fixed EXT4 File System Parser bug: 64bit addressing was handled incorrectly, thus some contents (directories/files) may be not parsed - EXT4 File System Parser is optimized, parsing is done much faster - Fixed file names encoding in EXT4 File System Parser. Now names are recognized as UTF-8 strings - when loading official firmware, the partitions list is automatically rewinded to always keep showing currently loaded partition progress; - reworked the main interface window - now parsed partitions list and File System contents explorer are moved to separate pages. - File System contents explorer now builds the list of all partitions detected with supported file systems at once; to initate the parsing of selected partition just enough to expand its tree node - added 'Preview' to the The contents explorer. It is possible to instantly start checking the selected file's conents - supported currently: text files, picture files, ELF files. To check the file it is not necessary to export it to the hard disk first, just click on file and in preview window the contents of the file will be displayed. - [Parse Official Firmware]: added support for Qualcomm XML programming files: to load click the "Parse Official Firmware" button and select Qualcomm's XML file (like rawprogram0.xml); Plugin will create list of partitions from it, will load required files into partitions and will be instantly ready to flash those into connected device. - Renamed old buttons 'Read Selected', 'Flash Selected' to 'Read Selected Full Area', 'Flash Selected Full Area' and added 'Flash Selected Used Area' button: it is possible now to flash either only the used area of partition or the full partition area. For example, if full partition size is 1GB, but the meaningfull data file injected into it was 1MB, there is no point flashing full partition area (1GB). Instead, to save time just first 1MB can be flashed with 'Flash Selected Used Area' button This feature is especially useful when flashing partitions after [Parse Official Firmware] is executed. - [Parse Official Firmware] - optimized parsing firmware file. Loading any firmware files now happen almost instantly. Plugin now works with external files of partitions on-the-fly, so it is not required now to waste time injecting file's data into partition during parsing stage. Sparse packed files are handled on-the-fly as well. All operations are performed in the background. From the user point of view, you just keep working with the parsed partitions as usually - as if local dump were loaded and parsed. |
The Following 7 Users Say Thank You to legija For This Useful Post: |
08-30-2018, 05:37 | #275 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1803458 Status: Offline Thanks Meter: 8 | Ufs - added UFS memories support via USB interface. Hello, more info please about this future. In what conditionmust be the phone?(working boot?) Can write fully erased memory? |
08-30-2018, 09:38 | #278 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
Please contact me via QQ if possible. QQ: 1634811353 | |
08-31-2018, 03:04 | #280 (permalink) |
Freak Poster Join Date: May 2011 Location: caracas venezuela
Member: 1575111 Status: Offline Sonork: chris259 Thanks Meter: 35 | perfect sir one question does zte z831 stock on dfu mode i can use resurrecion or does go tru emmc i just dont know que you guide me there |
09-07-2018, 06:57 | #281 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | eMMCDiskPartitions.dll Download and install Successful but No option of eMMCDiskPartitions plug in usefull plug in tab how to solve ? riff v1 box running on trial period . |
09-08-2018, 13:15 | #283 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | i cant download the las version of soft please need direct links when try to enter to sopport direct to riif soft never finish to enter need help support thanks support |
09-10-2018, 09:28 | #284 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: uganda
Member: 705986 Status: Offline Thanks Meter: 11 | pinouts for mtk/spd emmc - how to connect Quote:
so how do i connect the emmc which pinout do i use because i usually see rx and tx pins on mtk pcbs and spd pcbs | |
