07-20-2011, 05:11 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 949006 Status: Offline Thanks Meter: 0 | RIFF HTC Incredible NAND Flash JTAG read HTC: Incredible Verizon RIFF Box JTAG Manager: Ver. 1.33 RIFF Box Firmware Version: 1.25 JTAG Pin Out confirmed with other operations. Possible MSM8255 CPU?? Can DCC Read ROM 1 @ 512 MB for the RAM HTC INcredible C ressurector installed. Looking to read the NAND Flash at 8 GB?? IS this possible, and if so, what process do I need? |
07-20-2011, 05:17 | #2 (permalink) |
Member: 949006 Status: Offline Thanks Meter: 0 | Error Messages include: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [HTC Incredible C] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 9 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) WARNING: Resuming interrupted read from 0x00A50000, yet to read - 0x1F5B0000... Reading MCU address space from 0x00A50000 to 0x1FFFFFFF Failed to receive answer to READ command. ************** Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [HTC Incredible C] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 18 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OKFAILED Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. ERROR: No response from the DCC Loader. Terminating. ****************** Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [HTC Incredible C] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) WARNING: Resuming interrupted read from 0x00A50000, yet to read - 0x1F5B0000... Reading MCU address space from 0x00A50000 to 0x1FFFFFFF Failed to receive answer to READ command. |
07-20-2011, 20:05 | #4 (permalink) |
Member: 949006 Status: Offline Thanks Meter: 0 | Thanks for response, can you point me in the right direction, I only found this for the Desire, does this apply for the Incredible? Since HTC Desire HD is phone based on quite new CPU (MSM8255) and in some important features different from other HTC phones, I am opening special thread for discussion. Before asking many questions, please take following in mind :
If by any case FSBL is deleted from phone memory, JTAG Access will be disabled, and You will not be able to do anything with phone for now. (CPU ID is detected, but connection will fail)
07-20-2011, 23:05 | #5 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | You were reading wrong topic. There is sticky topic called "Important manuals" i am too lazy to copy direct link, but I think if You put some efforts You'll find it Your self. |
07-21-2011, 03:57 | #6 (permalink) |
Member: 949006 Status: Offline Thanks Meter: 0 | Did lots of reading, tell me if I did enough (-: I got this read but this is still only the RAM @512 MB, I am looking to read the 8 GB NAND chip, is that possible, yes or no.....if yes, then I will do more reading, BTW, thanks for the help so far.... This is what I can read: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [HTC Incredible C] Connecting to the dead body...OK Detected dead body ID: 0x202800E1 - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) WARNING: Resuming interrupted read from 0x00A50000, yet to read - 0x1F5B0000... Reading FLASH1 address space from 0x00A50000 to 0x1FFFFFFF What do I do to read the 8 GB NAND? |
07-21-2011, 04:31 | #7 (permalink) |
Member: 949006 Status: Offline Thanks Meter: 0 | Another read complete, but stil not the NAND 8 GB chip, still reading and trying (-: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [HTC Incredible C] Reading Target Memory...OK Completed in 00:15:06.234 (Average Transfer Rate: 144.63 kB/s) Saved OK |
07-21-2011, 05:07 | #8 (permalink) |
Member: 949006 Status: Offline Thanks Meter: 0 | I am looking to recover the user data on the NAND 8GB memory, phone is damage and need data to put on new phone of same make and model. Can we read and write to this type of memory? I see that we can read and write to the RAM area where the firmware resides. Thanks again for your help..... |
07-21-2011, 10:51 | #9 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | NAND size is 512MB, and what You want to do is to read ROM2 eMMC or iNAND. If phone has $andi$k chip inside, that would be it. DCC loader in this DLL does not support this kind of memory, since it isnt important in repair process. |
The Following User Says Thank You to legija For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
