05-03-2013, 22:30 | #77 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I see you have i9000....But You did use I9003 Photo..? Maybe you did write efs/modem from I9003...? As I know,EFS part is same but modem file is different |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
05-04-2013, 07:26 | #79 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please See This: http://forum.gsmhosting.com/vbb/8813024-post2.html I Think You Can Use I997r efs File.... I Mean efs is Same But Modem is Different Thanks |
05-06-2013, 22:08 | #81 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Please Uncheck "Image File is Used " Also Uncheck "Auto Full Flash Size" and Put Correct Address manually | |
05-08-2013, 07:28 | #83 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote: Because You Set address Like I9100..... You Need Write efs With I9000/9003 Address see plz: http://forum.gsmhosting.com/vbb/8816284-post5.html | |
05-08-2013, 08:37 | #84 (permalink) |
Crazy Poster Join Date: Sep 2011 Location: Makrana Age: 34
Member: 1646893 Status: Offline Sonork: 100.1585581 Thanks Meter: 3 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [ZTE S1602 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x26010000000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0020/0x88C0 (8MB) Writting FLASH1 memory from 0x000000000000 to 0x0000007FFFFF ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 |
05-10-2013, 15:15 | #86 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | Quote:
im sure fro i9000 full dump that pic is wrong but i had testing 2 solution efs part and modem part but all times show writting successfully after writting firmware with odin show in phones lcd, efs part damage and same resualt then power on and imei and baseband show noll for me, so can i solve this problem without hardware? thanks | |
05-10-2013, 22:12 | #87 (permalink) | |
if you see "can't mount efs " in recovery menu,,Try This 1-Full erase via RIFF-Box 2-Repair Boot With Select "Gremlin" 3-flash phone with any 3parts firmware + .pit File and repartition on Odin -Then,Try Reset "EFS" By SPT After Done,Try Write efs by "DCC Page" Via RIFF again If Phone Have a SW Problem,Must be Repair and Back to Work Anyway,,,Plz Make Sure About Exactly Model...in last month i see 5pcs M110s Flashed With I9000 Firmware and Imei/BB Gone | |
05-11-2013, 09:46 | #88 (permalink) | |
Member: 592636 Status: Offline Thanks Meter: 674 | thanks dear babak Quote:
are these process same as i9000t? Last edited by soshan; 05-11-2013 at 09:55. | |
05-11-2013, 10:23 | #89 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi soshan Gremlin Zone Mean repair MoviNand...select Recovery and kernel.... --- So,In New dll you Can See 2 Different Boot, and see Repair Recovery.... if you have any question,Plz Contact Me Via Sonork |
