Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 01-09-2012, 09:17   #16 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
I9023 Good EFS needed
regarnig to this thread
And as it seems i9023 boot repaier alone is not enough
please attach good EFS to test it from working phone,
Thanks in Advance
Old 01-09-2012, 17:53   #17 (permalink)
Member: 18028
if still empty do you know what can be wrong?i have 2 with same problem.hw look ok little liquid in micro usb after clean usb work but imei empty.
b.r
Old 01-10-2012, 01:19   #18 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
b.r
br. , try in this order ,
first flash with riff the efs in this thread,
then flash this firmware:
Hotfile.com: One click file hosting: I9100XWKK5_I9100OXXKJ3.rar
inside are also APBOOT and EFS , first flash with repartion ticked , phone bootloader update and phone efs clear, the code , csc and modem ,
after that flash again EFS in pda , with autoreboot ticked and F.reset time,
then , flash kernel for rooting and repair efs and imei with z3x ,
atlast reflash again pda. csc and modem but with autoreboot ticked and F.reset time only... it worked for me , SGS2 is alive and kicking now
p.s. pass for firmware archive is : ****************
Old 01-14-2012, 12:49   #19 (permalink)
Member: 175156
after flash the fs file ( phone want password to enter to menu ) and after that to connect with z3x box
note : aftr repair i9100 efs file with riff box the imei is still empty
thanks
Old 01-14-2012, 13:21   #20 (permalink)
Member: 175156
after flash the efs file ( phone want password to enter to menu ) and after that to connect with z3x box
thanks
Old 01-14-2012, 22:04   #21 (permalink)
Member: 892657
Here, I described a simpler way to repair samsung i9100 EFS.
Repair IMEI S2
Old 01-15-2012, 01:03   #22 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
thanks
after write efs file with riff box imei should be 00449........
if not repeat procedure or reflash firmware then flash efs with riff,
to clear the password , need to flash the firmware i posted
and reflash EFS file inside the archive , with odin not riff again
Old 01-17-2012, 09:24   #23 (permalink)
Member: 95960
Sonork: 100.1574721
any news regarding this ???
to revive phone
Old 01-17-2012, 09:49   #24 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
do you have full working dump? i need this..
Old 01-19-2012, 13:04   #25 (permalink)
Member: 95960
Sonork: 100.1574721
waitting for Riff box team
Old 01-26-2012, 22:32   #26 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
ok.i find it(full dump)
if you need please contact me on sonorok
Old 02-02-2012, 22:02   #27 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
babak send me sonork id private
Old 02-02-2012, 22:13   #28 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
i9023 with riff 3x time ı try always black LCD after ı try with medusa phone LCD ok..
Riff boot after odin with CSC always fail...
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.30, JTAG Manager Version: 1.38
Selected Resurrector: [Samsung I9023]
Connecting to the dead body...OK
Detected dead body ID: 0x1BA00477 - CORRECT!
Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Flashing the dead body...OK
WARNING: Programming Error (0x24) at 0x00010C0000 is handled as Cut Excess.
Resurrection complete!
MEDUSA LOG
Selected device model: Samsung GT-I9023
Connecting. Please wait...
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision B.
Detected TAP ID: 1BA00477, IR Length = 4.
MI: Halting target, attempt 1.
MI: ARM CoreSight DAP detected.
MI: CPUID = 43110222.
JTAG speed : 12000 KHz.
VREF level : 2.74 V
CPU : Samsung S5PC110
Core ID : 1BA00477
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000135.
MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL
MI: Watchdog are preconfigured.
MI: Server init.
MI: Received flash ID 0xB0EC0050.
MI: Flash geometry set.
MI: Recheking settings... ok
Server caps : 00000135
Flash device: Samsung KFG4GH6Q4M
Flash ID : 00EC0050
Page size : 4096 bytes
Block size : 64 pages (256 Kb)
Block count: 2048
Flash size : 512 Mb
Write protection disabled.
Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9023_Re pair.mf" file...
Writting BOOT section. Please wait... Done
Writting UPCH section. Please wait... Done
Disconnected
<ID:0/004> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Bootloader_I9023XXKA3.tar.md5 is valid.
<OSM> PDA_SOJU_GRJ22_TMO_EUR_MR2_SIGNED.tar.md5 is valid.
<OSM> MODEM_I9023XXKD1_REV_00_CL990283_SIGNED.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> Odin v.3 engine (ID:4)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<OSM> All threads completed. (succeed 0 / failed 1)
<ID:0/004> Removed!!
<ID:0/004> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/004> Initialzation..
<ID:0/004> Get PIT for mapping..
<ID:0/004> Firmware update start..
<ID:0/004> bootloader.img
<ID:0/004> NAND Write Start!!
<ID:0/004> boot.img
<ID:0/004> recovery.img
<ID:0/004> system.img
<ID:0/004> userdata.img
<ID:0/004> radio.xx.img
<ID:0/004> Transmission Complete..
<ID:0/004> Now Writing.. Please wait about 2 minutes
<ID:0/004> Receive Response form LOKE
<ID:0/004> dgs.img
<ID:0/004>
<ID:0/004> Complete(Write) operation failed.
<ID:0/004> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/004> boot.img
<ID:0/004> dgs.img
<ID:0/004> RQT_CLOSE !!
<ID:0/004> RES OK !!
<ID:0/004> Completed..
<OSM> All threads completed. (succeed 1 / failed 0)
Old 02-03-2012, 10:35   #29 (permalink)
Member: 598417
mustafa bey çok güzelde bu efs tamiride yapmışmı ben yapamadım kaç aydır elimde bekleyen cihaz var?
Old 02-19-2012, 16:50   #30 (permalink)
Member: 1282387
Originally Posted by The_Killer View Post
Hi All
Happy New Year
This How To Repair imei in I9100 with Riff Jtag
1.Read EFS From Working I9100
From 0x0000400000
and Length 0x0001400000
Rom1
2.Write EFS in the Target Phone with the same address
3.After Finish Writing Just Repair imei with any tool Like Z3X Or SPT
Note: if serial after repairing become To 0499xxxxxxx This mean Your Phone will done
but If it become Blank this mean its a Hardware Problem
This ISThe EFS file used in repairing I9100 EFS
Hope To U Nice Repairing
HAPPY NY 2012
AND THANX Gose To Legija Riff Team Magician
Where to connect the device?
Computer with a usb?
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-08-1999 14:22
Imei Arnis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-15-1999 02:38
Page generated in 0.39541 seconds with 12 queries
