05-23-2011, 10:02 | #167 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_Mozart.dll & HTC_Trophy ------------------------------------- - Finally fixed an issure about ModelID. So ModelID is will now again be resurrected. Those who have ModelID error just make resurrection again and all will be ok. |
The Following 4 Users Say Thank You to legija For This Useful Post: |
05-24-2011, 18:33 | #168 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Samsung_S5260.dll ------------------------------------- - DCC Loader was accidentially replaced with wrong data. Now is ok. |
The Following 8 Users Say Thank You to legija For This Useful Post: |
06-10-2011, 19:20 | #169 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Samsung_S5830.dll ------------------------------------- - added ID 0x203C10E1 to allowed list HTC_Incredible_C.dll ------------------------------------- - fixed bug in DCC Loader: during flashing after first bad block met all further blocks were erroneously detected as bad. |
The Following User Says Thank You to legija For This Useful Post: |
06-10-2011, 19:33 | #170 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 10.06.2011 More CDMA Models, new bug fix updates today Whats new : CDMA Models JTAG support :
06-16-2011, 16:53 | #171 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 16.06.2011 RIFF JTAG – HTC Desire HD A9191 (HTC Ace) Unbrick, IMEI, CID, ModelID, Simlock repair Resurrecting HTC Desire HD is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. Some (or all) revisions of HTC Desire HD boards have JTAG interface disabled (that is enable MARM JTAG Fuse is ****n in the MSM8255 chip). In this case the JTAG may be enabled only by firmware itself. This is done by the FSBL loader, so writing to FSBL area is artificially disabled in the DCC Loader code. DCC Loader will discard all flashing attempts into FSBL zone and will respond with success code as if flashing succeeded. In this way FSBL zone is protected while user still can flash full image files seamlessly. Resurrector will reflash radio’s boot zone (except FSBL area) and will re-write PDA’s SPL to 0.85.0007 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PD9810000′. There is option to reflash BOOT and RECOVERY zones. If selected, then ClockworkMod Recovery v3.0.2.8 will be flashed. Please note, if your phone has the FSBL loader damaged and MCU has JTAG FUSE ****n then there is no way to resurrect your phone via JTAG interface. To resurrect HTC Desire HD:
To enter download mode:
The Following 12 Users Say Thank You to legija For This Useful Post: |
06-22-2011, 12:50 | #172 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 22.06.2011 CDMA day again, 3 new models supported Whats new:
06-22-2011, 15:16 | #173 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 22.06.2011 Samsung Galaxy S 4G (T959v 1GB) Unbrick – Boot repair supported Samsung T959V is based on the S5PCxxx Processor (ARM core is Cortex-A8). Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. But note, in very rare cases it is possible that you will have to hold Power On key during initial connection. In case after resurrection (after you have tried with both boot versions) the download mode is not initiated (LCD remains blank) do repeat resurrection with ‘Clone Gremlin zone’ option checked. To resurrect Samsung T959V:
The Following 2 Users Say Thank You to legija For This Useful Post: |
07-01-2011, 11:09 | #174 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_HD7.dll ------------------------------------- - fixed bug in DCC Loader: during flashing after first bad block met all further blocks were erroneously detected as bad. |
The Following 3 Users Say Thank You to legija For This Useful Post: |
07-07-2011, 15:51 | #175 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 07.07.2011 HTC Wildfire S A510E (HTC Marvel), More CDMA models supported. Resurrecting HTC WildFireS is easy. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. In case you have no USB cable near, make sure battery is charged enough and hold Power On button during initiation of JTAG connection. Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 1.01.0002 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PC4910000′. Additionally, you can check ‘Repair RECOVERY zones’ to reflash android BOOT and RECOVERY code. To resurrect HTC WildFireS:
Following CDMA models are supported from today :
07-12-2011, 12:20 | #176 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 12.07.2011 Samsung T749, Samsung E189 Unbrick – Boot repair supported The Samsung T749 board is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. To resurrect Samsung T749:
In case you cannot find firmware files use Global RIFF Link & Data Exchange plugin – at the moment of resurrector release there was shared full dump from alive Samsung T749 phone. To enter download mode:
Resurrecting Samsung E189 is simple. Phone is auto powered on with USB Cable connected to the PC. Battery presence is not required; connection can be established with detached board. Current resurrector contains Firmware and EEPROM zones for memory chip with ID 0x00EC/0×2256 To resurrect Samsung E189:
Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. |
07-15-2011, 14:50 | #177 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_Wildfire.dll ------------------------------------- - Added feature to flash RECOVERY and BOOT zones during resurrection. - Added code reading option HTC_WildfireS.dll ------------------------------------- - By mistake was released DLL for usual HTC Wildfire model. Now is ok. Thanks to Tatek and Basar for help. Free beers for both |
07-15-2011, 19:52 | #178 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 15.07.2011 Qtek 9000 (HTC Universal) Unbrick – Boot repair supported Current resurrector works with Qtek 9000 with MDOC G3 memory version. In order to establish JTAG connection charged battery is required. In some cases you will need to press power on key during initiating connection. Please note, in case the Download Mode Initiation resurrection way is selected in the resurrector popup settings window, battery must be charged enough in order for phone to enter download mode. Current resurrector offers 2 ways to resurrect the phone:
************************************************** ************** Detected a Not Initialized FLASH1 Chip ID: 0×0200/0xFDFF ERROR: Selected FLASH Chip was not initialized by the DCC Loader ************************************************** ************** In this case resurrection of your device is not possible. We advise you to solder a new flash memory chip and then use resurrector with IPL re-flash enabled. To resurrect Qtek 9000 G3:
07-29-2011, 10:10 | #180 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_WildfireS.dll ------------------------------------- - corrected HTC partition position Eten_X800.dll ------------------------------------- - corrected mistake in JTAG pinout |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-21-1999 11:05 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
