10-07-2011, 11:46 | #211 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 07.10.2011 Samsung i997 infuse 4g Unbrick, Boot repair supported Samsung I997 is based on the S5PCxxx Processor (ARM core is Cortex-A8). Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. But note, in very rare cases it is possible that you will have to hold Power On key during initial connection. In case after resurrection (after you have tried with both boot versions) the download mode is not initiated (LCD remains blank) do repeat resurrection with ‘Clone Gremlin zone’ option checked. To resurrect Samsung I997:
To enter download mode:
The Following 2 Users Say Thank You to legija For This Useful Post: |
10-07-2011, 20:38 | #212 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 07.10.2011 Samsung Galaxy II, OMAP4430 version supported (Samsung i9100G, Samsung i9108) Samsung I9108 is based on the OMAP4430 Processor (Cortex-A9 Dual-Core). JTAG pads are very small; professional experience in soldering is required to connect wires to the JTAG interface. There is a big variety of versions of Galaxy II devices: GT-I9100, GT-I9100G, GT-I9100L, GT-I9100M, GT-I9100T, GT-I9101, GT-I9103, GT-I9108, GT-I9188, and maybe more. Some of them are based on different hardware platform – the Samsung S5PV310 (Cortex-A9 Dual-Core). Thus make sure first which exact hardware version you have on hands. Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. Current DLL is still a beta one. It will work only with phones which have killed X-Loader. To resurrect Samsung I9108:
The Following 7 Users Say Thank You to legija For This Useful Post: |
10-12-2011, 13:38 | #213 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 12.10.2011 HTC Desire Z (HTC Vision) Unbrick, Unlock, IMEI&CID repair supported Resurrecting HTC Desire Z is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. Some (or all) revisions of HTC Desire Z boards have JTAG interface disabled (that is enable MARM JTAG Fuse is ****n in the MSM7230 chip). In this case the JTAG may be enabled only by firmware itself. This is done by the FSBL loader, so writing to FSBL area is artificially disabled in the DCC Loader code. DCC Loader will discard all flashing attempts into FSBL zone and will respond with success code as if flashing succeeded. In this way FSBL zone is protected while user still can flash full image files seamlessly. Resurrector will reflash radio’s boot zone (except FSBL area) and will re-write one of selected PDA’s SPL versions (0.76.2000 or 0.85.0005). Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PC1010000’. There is option to reflash BOOT and RECOVERY zones. Please note, if your phone has the FSBL loader damaged and MCU has JTAG FUSE ****n then there is no way to resurrect your phone via JTAG interface. To resurrect HTC Desire Z:
The Following 3 Users Say Thank You to legija For This Useful Post: |
10-18-2011, 13:37 | #214 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Samsung_S5660.dll ------------------------------------- - ID 0x203C00E1 is added to allowed list Samsung_S5830.dll ------------------------------------- - ID 0x503C10E1 is added to allowed list |
The Following 4 Users Say Thank You to legija For This Useful Post: |
10-20-2011, 19:01 | #215 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | 19.10.2011 RIFF JTAG – Samsung Z500 supported ! Resurrection of Samsung Z500 requires battery or external power supply (we didn’t test whether phone is powered on using only a USB cable). You can use RIFF BOX’s 4.2V output for power (requires 1.16 firmware version or later and the 4.2V Output feature enabled in the JTAG Manager). To resurrect Samsung Z500:
The Following User Says Thank You to M0YAL For This Useful Post: |
10-24-2011, 12:49 | #216 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 19.10.2011 RIFF JTAG – Samsung Z500 supported ! Resurrection of Samsung Z500 requires battery or external power supply (we didn’t test whether phone is powered on using only a USB cable). You can use RIFF BOX’s 4.2V output for power (requires 1.16 firmware version or later and the 4.2V Output feature enabled in the JTAG Manager). To resurrect Samsung Z500:
10-24-2011, 12:54 | #217 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 24.10.2011 Samsung Corby II – S3850 supported Samsung S3850 resurrection is simple. Battery is not required. To power the board it’s most convenient to use an USB Data Cable. In orger to contact to JTAG pads you may need to carefully scratch off paint covering (mask layer) above them. To resurrect Samsung S3850 do this:
10-24-2011, 14:31 | #218 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 24.10.2011 HTC Supersonic (EVO 4G) Unbrick, Unlock, IMEI, CID, ModelID repair supported Resurrecting HTC Supersonic (EVO 4G) is easy. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. In case you have no USB cable near, make sure battery is charged enough and hold Power On button during initiation of JTAG connection. Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 2.16.0001 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PC3610000’. Additionally, you can check ‘Repair RECOVERY zones’ to reflash android BOOT and RECOVERY code. If selected, then ClockworkMod Recovery v5.0.2.2 will be flashed. Using this recovery you will be able to install zip files from the SD Card, for example you will be able to acquireROOT rights by installing su-2.3.6.3-efgh-signed.zip file. To resurrect HTC Supersonic:
The Following 6 Users Say Thank You to legija For This Useful Post: |
10-24-2011, 22:16 | #219 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_DesireHD.dll ------------------------------------- - ID 0x27B360E1 is added to allowed list |
10-24-2011, 22:26 | #220 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 24.10.2011 HTC Desire CDMA Supported Resurrecting HTC Desire CDMA is easy. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. In case you have no USB cable near, make sure battery is charged enough and hold Power On button during initiation of JTAG connection. Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 1.60.0000 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PP9940000’. Additionally, you can check ‘Repair RECOVERY zones’ to reflash android BOOT and RECOVERY code. To resurrect HTC Desire CDMA:
10-24-2011, 22:31 | #221 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 24.10.2011 LG SH860 Supported Resurrecting LG SH860 is easy. To establish connector battery must be connected and Power On key to be pressed. To resurrect LG SH860:
To enter emergency mode:
10-26-2011, 18:19 | #222 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 26.10.2011 Samsung Galaxy S Plus (i9001) Unbrick, boot repair supported Resurrecting Samsung I9001 is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. Please note, MSM8255T is dual core chipset – it has ARM11 and Qualcomm Scorpion cores. During power on sequence only ARM11 core is visible on the JTAG chain. If boots are not completely damaged and it comes up to initializing of the Scorpion core then Scorpion core appears on the JTAG chain too. This will shift ARM11 from TAP0 into TAP1 position on the chain, while current resurrector has the ARM11 core hardcoded at TAP0 position. Thus make sure to establish JTAG connection in the time range while Scorpion core is not visible yet. To resurrect Samsung I9001:
10-28-2011, 16:24 | #223 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 28.10.2011 CDMA ZTE R518 supported Resurrecting ZTE R518 is easy. Battery is not required. To power the board it’s most convenient to use an USB Data Cable To resurrect ZTE R518:
The Following User Says Thank You to legija For This Useful Post: |
10-28-2011, 16:25 | #224 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 28.10.2011 Samsung M820 Galaxy Prevail Unbrick, Boot repair supported Samsung M820 resurrection is simple. Phone is auto powered when USB Data Cable is inserted while battery is inside. If you don’t use USB cable, make sure to hold Power On button during JTAG connection establishing phase. To resurrect Samsung M820 do this:
Now phone is in bootable condition, that is, even if it does not start up normally, you can flash it using original Samsung downloader software to restore it to the working state. To enter download mode:
10-28-2011, 16:26 | #225 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 28.10.2011 Samsung i9003 Galaxy SL Unbrick, Boot repair supported Samsung I9003 is based on the OMAP3630 (ARM core is Cortex-A8). Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. But note, in very rare cases it is possible that you will have to hold Power On key during initial connection. In case after resurrection (after you have tried with both boot versions) the download mode is not initiated (LCD remains blank) do repeat resurrection with ‘Clone Gremlin zone’ option checked. Please note, in most cases you will be required to insert Samsung I9003 RIFF™ MagicCard into phone’s SD slot before starting resurrection. In case you don’t have such card yet, you can create it on the “Samsung I9003 RIFF™ MagicCard” page of the resurrector settings dialog. Due to OMAP3630’s some peculiar TrustZone security features current resurrector may fail to boot: if this happens, use Samsung I9003 IRAM resurrector – which works much slower but boots without problems. To resurrect Samsung I9003:
The Following 13 Users Say Thank You to legija For This Useful Post: |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-21-1999 11:05 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
