Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #106 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Age: 44
Member: 256342 Status: Offline Sonork: 100.45940 Thanks: 127
| 18.02.2011 HTC P3300 (HTC Artemis 100) Unbrick – Boot Repair Supported Please start JTAG Manager and click “Check for Updates” button. You’ll be notified about new DLL, download it and restart the software. “HTC_Artemis.dll” contains pinout, instructions and required repair files for HTC P3300 (HTC Artemis 100) Unbrick – Boot Repair. ![]() |
| | #107 (permalink) |
| 03.03.2011 ZTE MF180S Broadband modem Unbrick/Repair supported Please start JTAG Manager and click “Check for Updates” button. You’ll be notified about new DLL, download it and restart the software. “ZTE_MF180S.dll” contains pinout, instructions and required repair files for ZTE MF180S Broadband modem Unbrick/Repair boot. ![]() |
| | #108 (permalink) |
| 04.03.2011 Samsung G800 Unbrick, dead boot repair supported Please start JTAG Manager and click “Check for Updates” button. You’ll be notified about new DLL, download it and restart the software. “Samsung_G800.dll” contains pinout, instructions and required repair files for Samsung G800 Unbrick, dead boot repair. ![]() |
| The Following User Says Thank You to legija For This Useful Post: |
| | #109 (permalink) |
| 10.03.2011 CDMA ZTE F285 Repair supported Resurrecting ZTE F285 is simple. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. Resurrector re-flashes only firmware zone of the phone (0×000000 to 0x60FFFF). To resurrect ZTE F285:
| | #110 (permalink) |
| 10.03.2011 ASUS P526 Unbrick, Dead Boot repair supported Resurrection of ASUS P526 is slightly complicated. JTAG pads are very small and sensitive thus extreme care must be taken when soldering wires to the board. Battery must be connected in order to establish JTAG connection. Current resurrector re-flashes only the IPL area, and will not re-write MDOC XLOADER area (though write of this area is supported too). Please note: DiskOnChip G4 memory has security features, due to which there is a risk of permanently blocking the access to the flash memory while re-flashing the XLOADER areas. Current resurrector will not touch the XLOADER zone, but it is possible you’re already holding such killed device in hands. If it is so you will see this error: ************************************************** ************** Detected a Not Initialized FLASH1 Chip ID: 0×0400/0xFBFF ERROR: Selected FLASH Chip was not initialized by the DCC Loader ************************************************** ************** This can happen due to unknown protection keys used or due to permanently blocked MDOC chip. If latter is true we advise you to solder a new flash memory chip or throw this phone away to the trash bin. To resurrect ASUS P526:
If phone not enters download mode after resurrection then it means XLOADER was damaged too but memory chip is still usable. In this case repeat resurrection using RAM Downloader Mode and when USB connection is established reflash the phone with official firmware. To enter download mode:
| | #111 (permalink) |
| 10.03.2011 HTC Desire DLL Update – Unlock Code reading supported New HTC Desire DLL has additional option to select between reading NCK Code, or direct unlock. This should also solve “error 0×45″ problem with some of the HW revisions. ![]() Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. |
| | #112 (permalink) |
| 10.03.2011 HTC Tattoo A3232 (HTC Click 1100) Unlock, Unbrick, IMEI repair, CID Update supported Resurrecting HTC Click is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is inside. There are two different hardware versions exist – one based on the MSM7225 chipset (CLIC10000) and other – on the ESM7225 chipset (CLIC11000). In resurrector settings you can select a desired version. Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 0.52.0001 SPL version. As well, you can change CID – for this make sure ‘Repair Custom ID’ field is checked in the Resurrection Guide dialog. To resurrect HTC Click:
To Unlock HTC Click :
| | #113 (permalink) |
| 11.03.2011 CDMA Huawei C5005 Unbrick – Repair supported Resurrecting Huawei C5005 is simple. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. Resurrector re-flashes only firmware zone of the phone (0×000000 to 0xBFFFFF). To resurrect Huawei C5005:
Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. ![]() |
| The Following 15 Users Say Thank You to legija For This Useful Post: |
| | #114 (permalink) |
| 12.03.2011 Samsung SGH-i607 BlackJack PDA Unbrick, Dead Boot repair supported Resurrecting Samsung i607 PDA part is easy. Phone requires battery presence in order to establish JTAG connection. If you additionally connect charger the phone will be auto powered on and there will be no need to press Power on key. In case you experience connection problems, de-power phone completely, disconnect charger (if it was used), then insert battery, click Resurrection button in the JTAG Manger and immediately (within 0…1 seconds) press Power On key. To unbrick Samsung i607 PDA part:
| | #115 (permalink) |
| 14.03.2011 CDMA Samsung SPH-D700 Galaxy S Epic 4G Unbrick, Dead Boot repair supported Samsung SPH-D700 is based on the S5PC110 Processor (ARM core is Cortex-A8). Depending on firmware state resurrection can be a bit confusing: for successful connection you will require charged battery. Please note – no matter whether you have USB cable or not – it must not be connected to phone. This is important. Resurrector will reflash IBL, PBL, SPL and PARAM areas. Additionally you can select KERNEL and RECOVERY partitions to be reflashed too. Though them are required only for recovery mode and not needed for following USB firmware update by Odin software. So if you don’t need recovery mode don’t select these 2 partitions – otherwise you will just waste time waiting for them to be reflashed. If after resurrection the download mode still cannot be initiated (LCD remains blank) do repeat resurrection with ‘Clone Gremlin zone’ option checked. To resurrect Samsung SPH-D700:
To enter download or recovery mode:
| The Following 4 Users Say Thank You to legija For This Useful Post: |
| | #116 (permalink) |
| 14.03.2011 Toshiba Portege G900 Unbrick, Dead Boot repair supported Resurrection of Toshiba Portégé G900 PDA part is not hard. Battery is required for successful HALT operation. If USB Data Cable is connected phone is auto powered on when battery is inserted. If during connect operation (“Establish communication with the phone…”) after 2-3 passes there is still no success (progress bar keeps running from 0 to 100% and so on) then remove battery and insert it again. If USB cable is not connected then press and hold Power On key. Current resurrector re-flashes only the EBOOT and secondary EBOOT area, and will not re-write IPL area (though write of this area is supported too). Please note: DiskOnChip G4 memory has security features, due to which there is a risk of permanently blocking the access to the flash memory while re-flashing the IPL areas. Current resurrector will not touch the IPL zone, but it is possible you’re already holding such killed device in hands. If it is so you will see this error: ************************************************** ************** Detected a Not Initialized FLASH1 Chip ID: 0×0400/0xFBFF ERROR: Selected FLASH Chip was not initialized by the DCC Loader ************************************************** ************** This can happen due to unknown protection keys used or due to permanently blocked MDOC chip. If latter is true we advise you to solder a new flash memory chip or throw this phone away to the trash bin. To resurrect Toshiba G900 PDA part:
To enter USB download mode:
| | #117 (permalink) |
| 17.03.2011 Huawei E153U Broadband modem unbrick – dead boot repair supported Resurrecting Huawei E153U is simple. Just make sure you solder all JTAG signals and insert modem into a USB port for it to get powered. If modem is not detected by RIFFBOX JTAG, disconnect JTAG connector, re-insert modem into USB and then connect back the JTAG connector. There are secured (QCSBL is signed) and non-secured (QCSBL is not signed) modem revisions exist. Resurrector will automatically detect board revision and will select proper data to be flashed. No matter what h/w revision is you can select which partitions are to be flashed during resurrection process. To resurrect Huawei E153U:
| | #118 (permalink) |
| 21.02.2011 RoverPC EVO V7 Unbrick – Dead boot repair supported RoverPC Evo V7 resurrection is simple. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. To resurrect RoverPC Evo V7:
| | #119 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2002 Location: gsmcity Age: 34
Member: 10505 Status: Offline Sonork: 100.40828 Thanks: 536
| 22.03.2011 Samsung GT-B7330 OmniaPRO Boot Repair Supported Please start JTAG Manager and click “Check for Updates” button. You’ll be notified about new DLL, download it and restart the software. “Samsung_B7330.dll” contains pinout, instructions and required repair files for Samsung GT-B7330 OmniaPRO Unbrick – Boot Repair. |
| The Following 3 Users Say Thank You to levsha For This Useful Post: |
| | #120 (permalink) |
| 31.03.2011 HTC Ozone XV6175 (HTC Chief) Unbrick, Boot Repair, Unlock, IMEI Repair, CID Update supported Resurrecting HTC Chief is easy: Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 0.44.0000 SPL version. Additionally, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘CEDA10000′. As well, you can change CID – for this make sure ‘Repair Custom ID’ field is checked in the Resurrection Guide dialog. To resurrect HTC Chief:
| The Following 3 Users Say Thank You to legija For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 12 | 09-02-2012 19:17 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 11-02-1999 09:45 |
| SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 10-21-1999 11:05 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
