Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 11-11-2011, 17:52   #1 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
RIFF JTAG – Unlock/IMEI/TA repair – SonyEricsson x8, x10, x10 Mini, x10 mini pro (e15
RIFF JTAG – Unlock/IMEI/TA repair – SonyEricsson x8, x10, x10 Mini, x10 mini pro (e15, e10,u20 etc)
Resurrecting SonyEricsson phones is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is inserted.
With current resurrector you can choose Unlock or Resurrection operation to perform. During resurrection, you can select which areas to be repaired. Please note, in some cases phone reports failure during firmware update: in this case you may need to select option to erase Modem SW zone during resurrection.
Example :
During Unlock operation full backup of relevant zones is made, thus you have no risk killing your phone permanently – you have always an option to restore your phone to its original condition with the backup file. Backup files are created in JTAG Manager root directory, in the folder ‘BackupFiles’.
Example :
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 11-11-2011, 17:56   #2 (permalink)
moinuddin111's Avatar
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
Question how to unlock xperia u20i
how to unlock xperia x10 mini pro
cpu is msm 7227
plz help me riff team
Old 11-11-2011, 18:06   #3 (permalink)
Member: 129834
Thanks Meter: 19
E15i unlock error :(
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.28, JTAG Manager Version: 1.37
Selected Resurrector: [SE E15i]
Connecting to the dead body...OK
Detected dead body ID: 0x203C00E1 - CORRECT!
Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55BC (512MB)
Selected Resurrection Data for the NAND Chip with Page size = 2KB
Backup Important Zones...OK
Preparing data. Please wait...ERROR
Sorry, current ROM is not supported yet!
Old 11-11-2011, 18:06   #4 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
cpu is msm 7227
http://forum.gsmhosting.com/vbb/f634...o-e15-1379830/
Old 11-11-2011, 18:10   #5 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Hi,
This is new bootrom, for now it's not supported.
Old 11-11-2011, 18:13   #6 (permalink)
Member: 129834
Thanks Meter: 19
ok, when it will be added ??
Old 11-11-2011, 18:14   #7 (permalink)
Member: 23633
Sonork: 100.1609236
Thanks Meter: 14
My X8 unlocked without problems
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Detected an Initialized FLASH1 Chip, ID: 0x0020/0x55BC (512MB)
Preparing data. Please wait...OK
Unlocking the Phone...OK
Unlock complete!
wbr
Old 11-11-2011, 18:16   #8 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Selected Resurrector: [SE X10i]
Detected dead body ID: 0x202400E1 - CORRECT!
Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB)
Flashing the dead body...OK
Resurrection complete!
Old 11-11-2011, 18:24   #9 (permalink)
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
ok how to backup plz say full procedger
Old 11-11-2011, 18:42   #10 (permalink)
tavoonly's Avatar
Member: 586318
Thanks Meter: 112
X10a + imei repair done... Smooth way
UNLOCKING + IMEI FIX DONE
[11/11/2011 10:46:51 a.m.] [START OPERATION_ID = FIRMWARE_UPDATE]
[11/11/2011 10:47:22 a.m.] Open serial port...OK
[11/11/2011 10:47:22 a.m.] Connecting to the RIFF Box...OK
[11/11/2011 10:47:22 a.m.] Setting Update Mode...OK
[11/11/2011 10:47:22 a.m.] Old Firmware Version: 1.27
[11/11/2011 10:47:22 a.m.] Updating Box's Firmware...OK
[11/11/2011 10:47:22 a.m.] Restarting box, please wait...OK
[11/11/2011 10:47:22 a.m.] Firmware Update Completed OK
[11/11/2011 10:47:22 a.m.] Current Firmware Version: 1.28
[11/11/2011 10:47:22 a.m.] [FINISH OPERATION_ID = FIRMWARE_UPDATE]
[11/11/2011 10:49:22 a.m.] [START OPERATION_ID = RESURRECT]
[11/11/2011 10:49:23 a.m.] Open serial port...OK
[11/11/2011 10:49:23 a.m.] Connecting to the RIFF Box...OK
[11/11/2011 10:49:23 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37
[11/11/2011 10:49:23 a.m.] Selected Resurrector: [SE X10i]
[11/11/2011 10:49:23 a.m.] Connecting to the dead body...ERROR
[11/11/2011 10:49:23 a.m.] ERROR: The RTCK Signal does not respond.
[11/11/2011 10:49:23 a.m.] [FINISH OPERATION_ID = RESURRECT]
[11/11/2011 10:49:37 a.m.] [START OPERATION_ID = RESURRECT]
[11/11/2011 10:49:38 a.m.] Open serial port...OK
[11/11/2011 10:49:38 a.m.] Connecting to the RIFF Box...OK
[11/11/2011 10:49:38 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37
[11/11/2011 10:49:38 a.m.] Selected Resurrector: [SE X10i]
[11/11/2011 10:49:38 a.m.] Connecting to the dead body...ERROR
[11/11/2011 10:49:38 a.m.] ERROR: The RTCK Signal does not respond.
[11/11/2011 10:49:38 a.m.] [FINISH OPERATION_ID = RESURRECT]
[11/11/2011 10:50:17 a.m.] [START OPERATION_ID = PLUGIN_EXECUTE]
[11/11/2011 10:50:29 a.m.] [FINISH OPERATION_ID = PLUGIN_EXECUTE]
[11/11/2011 10:51:33 a.m.] [START OPERATION_ID = RESURRECT]
[11/11/2011 10:51:49 a.m.] Open serial port...OK
[11/11/2011 10:51:49 a.m.] Connecting to the RIFF Box...OK
[11/11/2011 10:51:49 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37
[11/11/2011 10:51:49 a.m.] Selected Resurrector: [SE X10i]
[11/11/2011 10:51:49 a.m.] Connecting to the dead body...OK
[11/11/2011 10:51:49 a.m.] Detected dead body ID: 0x202400E1 - CORRECT!
[11/11/2011 10:51:49 a.m.] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
[11/11/2011 10:51:49 a.m.] Adaptive Clocking RTCK Sampling is: [Sample at MAX]
[11/11/2011 10:51:49 a.m.] Resurrection sequence started.
[11/11/2011 10:51:49 a.m.] Establish communication with the phone...OK
[11/11/2011 10:51:49 a.m.] Initializing internal hardware configuration...OK
[11/11/2011 10:51:49 a.m.] Uploading resurrector data into memory...OK
[11/11/2011 10:51:49 a.m.] Starting communication with resurrector...OK
[11/11/2011 10:51:49 a.m.] Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB)
[11/11/2011 10:51:49 a.m.] Selected Resurrection Data for the NAND Chip with Page size = 2KB
[11/11/2011 10:51:49 a.m.] Backup Important Zones...OK
[11/11/2011 10:51:49 a.m.] Preparing data. Please wait...OK
[11/11/2011 10:51:49 a.m.] Unlocking the Phone...OK
[11/11/2011 10:51:49 a.m.] Unlock complete!
[11/11/2011 10:51:49 a.m.] [FINISH OPERATION_ID = RESURRECT]
[11/11/2011 11:33:15 a.m.] [START OPERATION_ID = RESURRECT]
[11/11/2011 11:34:01 a.m.] Open serial port...OK
[11/11/2011 11:34:01 a.m.] Connecting to the RIFF Box...OK
[11/11/2011 11:34:01 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37
[11/11/2011 11:34:01 a.m.] Selected Resurrector: [SE X10i]
[11/11/2011 11:34:01 a.m.] Connecting to the dead body...OK
[11/11/2011 11:34:01 a.m.] Detected dead body ID: 0x202400E1 - CORRECT!
[11/11/2011 11:34:01 a.m.] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
[11/11/2011 11:34:01 a.m.] Adaptive Clocking RTCK Sampling is: [Sample at MAX]
[11/11/2011 11:34:01 a.m.] Resurrection sequence started.
[11/11/2011 11:34:01 a.m.] Establish communication with the phone...OK
[11/11/2011 11:34:01 a.m.] Initializing internal hardware configuration...OK
[11/11/2011 11:34:01 a.m.] Uploading resurrector data into memory...OK
[11/11/2011 11:34:01 a.m.] Starting communication with resurrector...OK
[11/11/2011 11:34:01 a.m.] Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB)
[11/11/2011 11:34:01 a.m.] Selected Resurrection Data for the NAND Chip with Page size = 2KB
[11/11/2011 11:34:01 a.m.] Preparing data. Please wait...OK
[11/11/2011 11:34:01 a.m.] Flashing the dead body...OK
[11/11/2011 11:34:01 a.m.] Resurrection complete!
[11/11/2011 11:34:01 a.m.] [FINISH OPERATION_ID = RESURRECT]
Old 11-11-2011, 18:48   #11 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
plz say full procedgure
no need backup auto backup just connect
Resurrecting SE U20i (X10 Mini Pro) is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is inserted.
During Unlock operation full backup of relevant zones is made, thus you have no risk killing your phone permanently - you have always an option to restore your phone to its original condition with the backup file. Backup files are created in JTAG Manager root directory, in the folder ‘BackupFiles’.
To resurrect SE U20i:
Solder JTAG cable to SE U20i JTAG pads;
Insert USB Data cable into board and PC;
Make sure SE U20i is selected in the list of models;
If you use only battery, press Power On key;
Click Resurrect button;
Wait till software signals a successful operation completion;
Disconnect power supply, de-solder JTAG wires;
Now phone is in bootable condition, that is, even if it does not start up normally, you can flash it using known flashing methods.
Most common errors:
The NRST signal is not connected. Please ALWAYS SOLDER THE NRST SIGNAL whenever it is present on the schematics. In case you have JIG please make sure NRST is routed, if not - solder wire manually.
Connection is unstable or cannot be established at all. Please make sure JTAG wires are of the SAME LENGTH and not exceed ~10..15 cm in length; make sure RTCK is selected; compensate signals propagation errors by adjusting the RTCK Sampling Frequency; for better stability, avoid using fixed TCK frequency.
Old 11-11-2011, 19:22   #12 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
i need full dump x10i readed by working phone....
Old 11-11-2011, 19:25   #13 (permalink)
Cheater -Don't Deal with him-
infogsm's Avatar
Member: 18022
Sonork: 1574868
Thanks Meter: 192
still done by jtag or by usb this time ?
br
Old 11-11-2011, 19:36   #14 (permalink)
Member: 459220
Sonork: 100.1590597
Thanks Meter: 85
Example :
Example :
legija and team RIFF are the best ever is left behind by wave I have in my hands
b,r
thxs for updatesss
Old 11-11-2011, 19:55   #15 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
br
offcorse need jtag..........
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.30008 seconds with 10 queries
