11-11-2011, 17:52 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | RIFF JTAG – Unlock/IMEI/TA repair – SonyEricsson x8, x10, x10 Mini, x10 mini pro (e15 Unlock/IMEI/TA repair – SonyEricsson x8, x10, x10 Mini, x10 mini pro (e15, e10,u20 etc) Resurrecting SonyEricsson phones is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is inserted. With current resurrector you can choose Unlock or Resurrection operation to perform. During resurrection, you can select which areas to be repaired. Please note, in some cases phone reports failure during firmware update: in this case you may need to select option to erase Modem SW zone during resurrection. Example : During Unlock operation full backup of relevant zones is made, thus you have no risk killing your phone permanently – you have always an option to restore your phone to its original condition with the backup file. Backup files are created in JTAG Manager root directory, in the folder ‘BackupFiles’. Example : |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
11-11-2011, 18:06 | #3 (permalink) |
Insane Poster Join Date: Mar 2005 Age: 49
Member: 129834 Status: Offline Thanks Meter: 19 | E15i unlock error :( Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [SE E15i] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Backup Important Zones...OK Preparing data. Please wait...ERROR Sorry, current ROM is not supported yet! |
11-11-2011, 18:06 | #4 (permalink) | |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
11-11-2011, 18:14 | #7 (permalink) |
Freak Poster Join Date: Mar 2003 Location: PL
Member: 23633 Status: Offline Sonork: 100.1609236 Thanks Meter: 14 | My X8 unlocked without problems Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [SE E15i] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0020/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Backup Important Zones...OK Preparing data. Please wait...OK Unlocking the Phone...OK Unlock complete! wbr |
11-11-2011, 18:16 | #8 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.28, JTAG Manager Version: 1.37 Selected Resurrector: [SE X10i] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Preparing data. Please wait...OK Flashing the dead body...OK Resurrection complete! |
11-11-2011, 18:42 | #10 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | X10a + imei repair done... Smooth way UNLOCKING + IMEI FIX DONE Code: [11/11/2011 10:46:51 a.m.] [START OPERATION_ID = FIRMWARE_UPDATE] [11/11/2011 10:47:22 a.m.] Open serial port...OK [11/11/2011 10:47:22 a.m.] Connecting to the RIFF Box...OK [11/11/2011 10:47:22 a.m.] [11/11/2011 10:47:22 a.m.] Setting Update Mode...OK [11/11/2011 10:47:22 a.m.] Old Firmware Version: 1.27 [11/11/2011 10:47:22 a.m.] Updating Box's Firmware...OK [11/11/2011 10:47:22 a.m.] Restarting box, please wait...OK [11/11/2011 10:47:22 a.m.] Firmware Update Completed OK [11/11/2011 10:47:22 a.m.] [11/11/2011 10:47:22 a.m.] Current Firmware Version: 1.28 [11/11/2011 10:47:22 a.m.] [FINISH OPERATION_ID = FIRMWARE_UPDATE] [11/11/2011 10:49:22 a.m.] [START OPERATION_ID = RESURRECT] [11/11/2011 10:49:23 a.m.] Open serial port...OK [11/11/2011 10:49:23 a.m.] Connecting to the RIFF Box...OK [11/11/2011 10:49:23 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37 [11/11/2011 10:49:23 a.m.] Selected Resurrector: [SE X10i] [11/11/2011 10:49:23 a.m.] [11/11/2011 10:49:23 a.m.] Connecting to the dead body...ERROR [11/11/2011 10:49:23 a.m.] ERROR: The RTCK Signal does not respond. [11/11/2011 10:49:23 a.m.] [FINISH OPERATION_ID = RESURRECT] [11/11/2011 10:49:37 a.m.] [START OPERATION_ID = RESURRECT] [11/11/2011 10:49:38 a.m.] Open serial port...OK [11/11/2011 10:49:38 a.m.] Connecting to the RIFF Box...OK [11/11/2011 10:49:38 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37 [11/11/2011 10:49:38 a.m.] Selected Resurrector: [SE X10i] [11/11/2011 10:49:38 a.m.] [11/11/2011 10:49:38 a.m.] Connecting to the dead body...ERROR [11/11/2011 10:49:38 a.m.] ERROR: The RTCK Signal does not respond. [11/11/2011 10:49:38 a.m.] [FINISH OPERATION_ID = RESURRECT] [11/11/2011 10:50:17 a.m.] [START OPERATION_ID = PLUGIN_EXECUTE] [11/11/2011 10:50:29 a.m.] [FINISH OPERATION_ID = PLUGIN_EXECUTE] [11/11/2011 10:51:33 a.m.] [START OPERATION_ID = RESURRECT] [11/11/2011 10:51:49 a.m.] Open serial port...OK [11/11/2011 10:51:49 a.m.] Connecting to the RIFF Box...OK [11/11/2011 10:51:49 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37 [11/11/2011 10:51:49 a.m.] Selected Resurrector: [SE X10i] [11/11/2011 10:51:49 a.m.] [11/11/2011 10:51:49 a.m.] Connecting to the dead body...OK [11/11/2011 10:51:49 a.m.] Detected dead body ID: 0x202400E1 - CORRECT! [11/11/2011 10:51:49 a.m.] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [11/11/2011 10:51:49 a.m.] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [11/11/2011 10:51:49 a.m.] [11/11/2011 10:51:49 a.m.] Resurrection sequence started. [11/11/2011 10:51:49 a.m.] Establish communication with the phone...OK [11/11/2011 10:51:49 a.m.] Initializing internal hardware configuration...OK [11/11/2011 10:51:49 a.m.] Uploading resurrector data into memory...OK [11/11/2011 10:51:49 a.m.] Starting communication with resurrector...OK [11/11/2011 10:51:49 a.m.] [11/11/2011 10:51:49 a.m.] Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB) [11/11/2011 10:51:49 a.m.] Selected Resurrection Data for the NAND Chip with Page size = 2KB [11/11/2011 10:51:49 a.m.] [11/11/2011 10:51:49 a.m.] Backup Important Zones...OK [11/11/2011 10:51:49 a.m.] Preparing data. Please wait...OK [11/11/2011 10:51:49 a.m.] Unlocking the Phone...OK [11/11/2011 10:51:49 a.m.] Unlock complete! [11/11/2011 10:51:49 a.m.] [FINISH OPERATION_ID = RESURRECT] [11/11/2011 11:33:15 a.m.] [START OPERATION_ID = RESURRECT] [11/11/2011 11:34:01 a.m.] Open serial port...OK [11/11/2011 11:34:01 a.m.] Connecting to the RIFF Box...OK [11/11/2011 11:34:01 a.m.] Firmware Version: 1.28, JTAG Manager Version: 1.37 [11/11/2011 11:34:01 a.m.] Selected Resurrector: [SE X10i] [11/11/2011 11:34:01 a.m.] [11/11/2011 11:34:01 a.m.] Connecting to the dead body...OK [11/11/2011 11:34:01 a.m.] Detected dead body ID: 0x202400E1 - CORRECT! [11/11/2011 11:34:01 a.m.] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [11/11/2011 11:34:01 a.m.] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [11/11/2011 11:34:01 a.m.] [11/11/2011 11:34:01 a.m.] Resurrection sequence started. [11/11/2011 11:34:01 a.m.] Establish communication with the phone...OK [11/11/2011 11:34:01 a.m.] Initializing internal hardware configuration...OK [11/11/2011 11:34:01 a.m.] Uploading resurrector data into memory...OK [11/11/2011 11:34:01 a.m.] Starting communication with resurrector...OK [11/11/2011 11:34:01 a.m.] [11/11/2011 11:34:01 a.m.] Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB) [11/11/2011 11:34:01 a.m.] Selected Resurrection Data for the NAND Chip with Page size = 2KB [11/11/2011 11:34:01 a.m.] [11/11/2011 11:34:01 a.m.] Preparing data. Please wait...OK [11/11/2011 11:34:01 a.m.] Flashing the dead body...OK [11/11/2011 11:34:01 a.m.] Resurrection complete! [11/11/2011 11:34:01 a.m.] [FINISH OPERATION_ID = RESURRECT] |
11-11-2011, 18:48 | #11 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | During Unlock operation full backup of relevant zones is made, thus you have no risk killing your phone permanently – you have always an option to restore your phone to its original condition with the backup file. Backup files are created in JTAG Manager root directory, in the folder ‘BackupFiles’ no need backup auto backup just connect Resurrecting SE U20i (X10 Mini Pro) is easy. Phone is auto powered on with USB Data Cable connected to the PC while battery is inserted. With current resurrector you can choose Unlock or Resurrection operation to perform. During resurrection, you can select which areas to be repaired. Please note, in some cases phone reports failure during firmware update: in this case you may need to select option to erase Modem SW zone during resurrection. During Unlock operation full backup of relevant zones is made, thus you have no risk killing your phone permanently - you have always an option to restore your phone to its original condition with the backup file. Backup files are created in JTAG Manager root directory, in the folder ‘BackupFiles’. To resurrect SE U20i: Solder JTAG cable to SE U20i JTAG pads; Insert USB Data cable into board and PC; Make sure SE U20i is selected in the list of models; If you use only battery, press Power On key; Click Resurrect button; Wait till software signals a successful operation completion; Disconnect power supply, de-solder JTAG wires; Now phone is in bootable condition, that is, even if it does not start up normally, you can flash it using known flashing methods. Most common errors: The NRST signal is not connected. Please ALWAYS SOLDER THE NRST SIGNAL whenever it is present on the schematics. In case you have JIG please make sure NRST is routed, if not - solder wire manually. Connection is unstable or cannot be established at all. Please make sure JTAG wires are of the SAME LENGTH and not exceed ~10..15 cm in length; make sure RTCK is selected; compensate signals propagation errors by adjusting the RTCK Sampling Frequency; for better stability, avoid using fixed TCK frequency. |
11-11-2011, 19:36 | #14 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: COLOMBIAA
Member: 459220 Status: Offline Sonork: 100.1590597 Thanks Meter: 85 | Quote:
legija and team RIFF are the best ever is left behind by wave I have in my hands b,r thxs for updatesss | |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
