06-22-2013, 07:45 | #1 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 727810 Status: Offline Sonork: 100.1627301 Thanks Meter: 167 | s5253 red light only need help team history of this handset is customer gave it to me in some facebook or other icons nt opening i tried to flash with z3x , then flashing failed handset came into download mode, then i tried multiloader then handset on bt hang on bada logo i tried everything every flash bt same condition , then i found babak sir solution first erase with riff then boot repair with any box , i erased with riff then try to boot repair , bt handset now nt showing downlaod mode , jst red light only and both team supporter nt even replying , can any help ... |
06-22-2013, 22:41 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I Told You ,Also I did Write Every Where...... NEED USB+JIG That's it...... ---- Let Me Explain... We Have 2 Different Jig For Force Start DL-Mode For Samsung 1-Called "JIG" 2-Called "USB+Jig" Jig : Only Clip.....It's Only USB Socket with Connected 1 Resistore 301K in Pin4 and 5 USB+Jig : This is Like Normal USB...Just Modify With 301k Resistor in Pin4 and 5 You Need USB+Jig..... 1-Connect USB To PC 2-Connect USB Socket To Phone (Battrey Already Put To Phone) After 3 sec You Can See Downloading Got it???? |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
