10-30-2013, 15:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | s5260 red screen after boot repair |
10-30-2013, 22:01 | #6 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Earth
Member: 6884 Status: Online Sonork: 100.1621477 Thanks Meter: 105 | use a microusb cable with jig, connect the cable to PC then to phone, show on odin if come on phone, when odin detect, flash the phone with pit |
10-30-2013, 22:52 | #9 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | I will try tommorow!!! Thanks but i dont think it will solve the problem as many users had this problem and no one helped them to solve it!!!! Sent from my iPhone using ******** |
10-31-2013, 13:01 | #11 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 1. Erase phone 2. Repair boot 3. Flash without battery with multiloader and all parts firmware 4. You may need cable with 303K resistor. |
The Following 2 Users Say Thank You to legija For This Useful Post: |
10-31-2013, 13:49 | #13 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | [30/10/2013 14:13:08] [START OPERATION_ID = DCC_ERASE_MEMORY] [30/10/2013 14:13:17] Open serial port...OK [30/10/2013 14:13:17] Connecting to the RIFF Box...OK [30/10/2013 14:13:17] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:13:17] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:13:17] [30/10/2013 14:13:17] Connecting to the dead body...OK [30/10/2013 14:13:17] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:13:17] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [30/10/2013 14:13:17] Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] [30/10/2013 14:13:17] Settings Code: 0x15010008000000000000000010000000 [30/10/2013 14:13:17] [30/10/2013 14:13:17] Resurrection sequence started. [30/10/2013 14:13:17] Establish communication with the phone...OK [30/10/2013 14:13:17] Initializing internal hardware configuration...OK [30/10/2013 14:13:17] Uploading resurrector data into memory...OK [30/10/2013 14:13:17] Starting communication with resurrector...OK [30/10/2013 14:13:17] [30/10/2013 14:13:17] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:13:17] [30/10/2013 14:13:17] Erasing FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF...OK [30/10/2013 14:13:17] WARNING: Erasing Error (0x24) at 0x000000420000 is Ignored. Erase continues. [30/10/2013 14:13:17] WARNING: Erasing Error (0x24) at 0x0000004E0000 is Ignored. Erase continues. [30/10/2013 14:13:17] Completed in 00:00:07.078 (Average Transfer Rate: 37036.45 kB/s) [30/10/2013 14:13:17] [FINISH OPERATION_ID = DCC_ERASE_MEMORY] [30/10/2013 14:13:26] [START OPERATION_ID = DCC_ERASE_MEMORY] [30/10/2013 14:13:39] Open serial port...OK [30/10/2013 14:13:39] Connecting to the RIFF Box...OK [30/10/2013 14:13:39] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:13:39] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:13:39] [30/10/2013 14:13:39] Connecting to the dead body...OK [30/10/2013 14:13:39] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:13:39] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [30/10/2013 14:13:39] Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] [30/10/2013 14:13:39] Settings Code: 0x05010008000000000000000010000000 [30/10/2013 14:13:39] [30/10/2013 14:13:39] Resurrection sequence started. [30/10/2013 14:13:39] Establish communication with the phone...OK [30/10/2013 14:13:39] Initializing internal hardware configuration...OK [30/10/2013 14:13:39] Uploading resurrector data into memory...OK [30/10/2013 14:13:39] Starting communication with resurrector...OK [30/10/2013 14:13:39] [30/10/2013 14:13:39] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:13:39] [30/10/2013 14:13:39] Erasing FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF...OK [30/10/2013 14:13:39] WARNING: Erasing Error (0x24) at 0x000000420000 is Ignored. Erase continues. [30/10/2013 14:13:39] WARNING: Erasing Error (0x24) at 0x0000004E0000 is Ignored. Erase continues. [30/10/2013 14:13:39] Completed in 00:00:11.860 (Average Transfer Rate: 22103.20 kB/s) [30/10/2013 14:13:39] [FINISH OPERATION_ID = DCC_ERASE_MEMORY] [30/10/2013 14:13:53] [START OPERATION_ID = RESURRECT] [30/10/2013 14:14:52] Open serial port...OK [30/10/2013 14:14:52] Connecting to the RIFF Box...OK [30/10/2013 14:14:52] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:14:52] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:14:52] [30/10/2013 14:14:52] Connecting to the dead body...OK [30/10/2013 14:14:52] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:14:52] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [30/10/2013 14:14:52] Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] [30/10/2013 14:14:52] [30/10/2013 14:14:52] Resurrection sequence started. [30/10/2013 14:14:52] Establish communication with the phone...OK [30/10/2013 14:14:52] Initializing internal hardware configuration...OK [30/10/2013 14:14:52] Uploading resurrector data into memory...OK [30/10/2013 14:14:52] Starting communication with resurrector...OK [30/10/2013 14:14:52] [30/10/2013 14:14:52] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:14:52] Selected Resurrection Data for the NAND Chip with Page size = 2KB [30/10/2013 14:14:52] [30/10/2013 14:14:52] Flashing the dead body...OK [30/10/2013 14:14:52] Resurrection complete! [30/10/2013 14:14:52] [FINISH OPERATION_ID = RESURRECT] [30/10/2013 14:15:33] [START OPERATION_ID = RESURRECT] [30/10/2013 14:16:25] Open serial port...OK [30/10/2013 14:16:25] Connecting to the RIFF Box...OK [30/10/2013 14:16:25] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:16:25] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:16:25] [30/10/2013 14:16:25] Connecting to the dead body...OK [30/10/2013 14:16:25] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:16:25] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [30/10/2013 14:16:25] Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] [30/10/2013 14:16:25] [30/10/2013 14:16:25] Resurrection sequence started. [30/10/2013 14:16:25] Establish communication with the phone...OK [30/10/2013 14:16:25] Initializing internal hardware configuration...OK [30/10/2013 14:16:25] Uploading resurrector data into memory...OK [30/10/2013 14:16:25] Starting communication with resurrector...OK [30/10/2013 14:16:25] [30/10/2013 14:16:25] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:16:25] Selected Resurrection Data for the NAND Chip with Page size = 2KB [30/10/2013 14:16:25] [30/10/2013 14:16:25] Flashing the dead body...OK [30/10/2013 14:16:25] Resurrection complete! [30/10/2013 14:16:25] [FINISH OPERATION_ID = RESURRECT] [30/10/2013 14:18:45] [START OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:18:47] Connecting to the Updates Server...ERROR [30/10/2013 14:18:47] ERROR: Couldn't connect to the Updates Server. Try again later. [30/10/2013 14:18:47] [FINISH OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:18:50] [START OPERATION_ID = FIRMWARE_UPDATE] [30/10/2013 14:18:51] Open serial port...OK [30/10/2013 14:18:51] Connecting to the RIFF Box...OK [30/10/2013 14:18:51] [30/10/2013 14:18:51] Getting RIFF Box Info...OK [30/10/2013 14:18:51] RIFF Box Firmware Version: 1.37 [30/10/2013 14:18:51] [30/10/2013 14:18:51] Connecting to the Updates Server...\ [30/10/2013 14:18:51] [FINISH OPERATION_ID = FIRMWARE_UPDATE] [30/10/2013 14:18:56] ------------------------------- JTAG Manager Session Opened ------------------------------- [30/10/2013 14:18:56] JTAG Manger Version: 1.54 [30/10/2013 14:18:56] ------------------------------------------------------------------------------------------- [30/10/2013 14:19:05] [START OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:20:11] Connecting to the Updates Server...OK [30/10/2013 14:20:11] Getting Updates Information from the Server...ERROR [30/10/2013 14:20:11] ERROR: Couldn't get the new Updates Information. [30/10/2013 14:20:11] [FINISH OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:21:32] [START OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:21:38] Connecting to the Updates Server...OK [30/10/2013 14:21:38] Getting Updates Information from the Server...ERROR [30/10/2013 14:21:38] ERROR: Couldn't get the new Updates Information. [30/10/2013 14:21:38] [FINISH OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:21:40] [START OPERATION_ID = GET_INFO] [30/10/2013 14:21:47] Open serial port...OK [30/10/2013 14:21:47] Connecting to the RIFF Box...OK [30/10/2013 14:21:47] [30/10/2013 14:21:47] Getting RIFF Box Info...OK [30/10/2013 14:21:47] RIFF Box S/N: FF.9737:9441-0C89:BB3E [30/10/2013 14:21:47] RIFF Box Firmware Version: 1.37 [30/10/2013 14:21:47] [FINISH OPERATION_ID = GET_INFO] [30/10/2013 14:22:51] [START OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:22:51] Connecting to the Updates Server...ERROR [30/10/2013 14:22:51] ERROR: Couldn't connect to the Updates Server. Try again later. [30/10/2013 14:22:51] [FINISH OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:22:53] [START OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:24:32] Connecting to the Updates Server...OK [30/10/2013 14:24:32] Getting Updates Information from the Server...OK [30/10/2013 14:24:32] Disconnecting from the Updates Server...OK [30/10/2013 14:24:32] [FINISH OPERATION_ID = CHECK_UPDATES] [30/10/2013 14:31:14] [START OPERATION_ID = DCC_WRITE_MEMORY] [30/10/2013 14:31:14] [30/10/2013 14:31:14] Current Settings: [30/10/2013 14:31:14] ----------------- [30/10/2013 14:31:14] Address: 000000000000 [30/10/2013 14:31:14] Length: 000010000000 [30/10/2013 14:31:14] Address Space: ROM1 [30/10/2013 14:31:14] AutoFullFlash: CHECKED [30/10/2013 14:31:14] Use End Address: UNCHECKED [30/10/2013 14:31:14] ECC Module Enabled: UNCHECKED [30/10/2013 14:31:14] Image File is Used: CHECKED [30/10/2013 14:31:14] Use Address as Offset: UNCHECKED [30/10/2013 14:31:14] Main (CHECKED): C:\Documents and Settings\tecno\Desktop\samsung gt-s5260 fullflash 03-02-2012 18_03_02.bin [30/10/2013 14:31:14] Redu (UNCHECKED): [30/10/2013 14:31:14] [30/10/2013 14:31:15] Open serial port...OK [30/10/2013 14:31:15] Connecting to the RIFF Box...OK [30/10/2013 14:31:15] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:31:15] Selected Resurrector: [Acer S100 V1.0.4841.57908] [30/10/2013 14:31:15] [30/10/2013 14:31:15] Connecting to the dead body...OK [30/10/2013 14:31:15] Detected dead body ID: 0x07926F0F - WRONG!!! [30/10/2013 14:31:15] ERROR: Current ID does not belong to the Acer S100 family. [30/10/2013 14:31:15] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [30/10/2013 14:31:24] [START OPERATION_ID = DCC_WRITE_MEMORY] [30/10/2013 14:31:24] [30/10/2013 14:31:24] Current Settings: [30/10/2013 14:31:24] ----------------- [30/10/2013 14:31:24] Address: 000000000000 [30/10/2013 14:31:24] Length: 000010000000 [30/10/2013 14:31:24] Address Space: ROM1 [30/10/2013 14:31:24] AutoFullFlash: CHECKED [30/10/2013 14:31:24] Use End Address: UNCHECKED [30/10/2013 14:31:24] ECC Module Enabled: UNCHECKED [30/10/2013 14:31:24] Image File is Used: CHECKED [30/10/2013 14:31:24] Use Address as Offset: UNCHECKED [30/10/2013 14:31:24] Main (CHECKED): C:\Documents and Settings\tecno\Desktop\samsung gt-s5260 fullflash 03-02-2012 18_03_02.bin [30/10/2013 14:31:24] Redu (UNCHECKED): [30/10/2013 14:31:24] [30/10/2013 14:52:03] Open serial port...OK [30/10/2013 14:52:03] Connecting to the RIFF Box...OK [30/10/2013 14:52:03] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:52:03] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:52:03] [30/10/2013 14:52:03] Connecting to the dead body...OK [30/10/2013 14:52:03] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:52:03] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [30/10/2013 14:52:03] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [30/10/2013 14:52:03] Settings Code: 0x25010000000000000000000010000000 [30/10/2013 14:52:03] [30/10/2013 14:52:03] Resurrection sequence started. [30/10/2013 14:52:03] Establish communication with the phone...OK [30/10/2013 14:52:03] Initializing internal hardware configuration...OK [30/10/2013 14:52:03] Uploading resurrector data into memory...OK [30/10/2013 14:52:03] Starting communication with resurrector...OK [30/10/2013 14:52:03] [30/10/2013 14:52:03] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:52:03] [30/10/2013 14:52:03] Writting FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF [30/10/2013 14:52:03] WARNING: Programming Error (0x24) at 0x000000420000 is Ignored. [30/10/2013 14:52:03] WARNING: Programming Error (0x24) at 0x0000004E0000 is Ignored. [30/10/2013 14:52:03] Completed in 00:20:37.969 (Average Transfer Rate: 218.37 kB/s) [30/10/2013 14:52:03] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [30/10/2013 14:53:32] [START OPERATION_ID = RESURRECT] [30/10/2013 14:53:32] Open serial port...ERROR [30/10/2013 14:53:32] ERROR: Cannot open serial port COM155 [30/10/2013 14:53:32] [FINISH OPERATION_ID = RESURRECT] [30/10/2013 14:53:35] [START OPERATION_ID = RESURRECT] [30/10/2013 14:53:59] Open serial port...OK [30/10/2013 14:53:59] Connecting to the RIFF Box...OK [30/10/2013 14:53:59] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:53:59] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:53:59] [30/10/2013 14:53:59] Connecting to the dead body...OK [30/10/2013 14:53:59] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:53:59] Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK [30/10/2013 14:53:59] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [30/10/2013 14:53:59] [30/10/2013 14:53:59] Resurrection sequence started. [30/10/2013 14:53:59] Establish communication with the phone...OK [30/10/2013 14:53:59] Initializing internal hardware configuration...OK [30/10/2013 14:53:59] Uploading resurrector data into memory...OK [30/10/2013 14:53:59] Starting communication with resurrector...OK [30/10/2013 14:53:59] [30/10/2013 14:53:59] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:53:59] Selected Resurrection Data for the NAND Chip with Page size = 2KB [30/10/2013 14:53:59] [30/10/2013 14:53:59] Flashing the dead body...OK [30/10/2013 14:53:59] Resurrection complete! [30/10/2013 14:53:59] [FINISH OPERATION_ID = RESURRECT] [30/10/2013 14:54:57] [START OPERATION_ID = DCC_ERASE_MEMORY] [30/10/2013 14:55:06] Open serial port...OK [30/10/2013 14:55:06] Connecting to the RIFF Box...OK [30/10/2013 14:55:06] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:55:06] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:55:06] [30/10/2013 14:55:06] Connecting to the dead body...OK [30/10/2013 14:55:06] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:55:06] Set I/O Voltage reads as 3.02V, TCK Frequency is RTCK [30/10/2013 14:55:06] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [30/10/2013 14:55:06] Settings Code: 0x04010000000000000000000010000000 [30/10/2013 14:55:06] [30/10/2013 14:55:06] Resurrection sequence started. [30/10/2013 14:55:06] Establish communication with the phone...OK [30/10/2013 14:55:06] Initializing internal hardware configuration...OK [30/10/2013 14:55:06] Uploading resurrector data into memory...OK [30/10/2013 14:55:06] Starting communication with resurrector...OK [30/10/2013 14:55:06] [30/10/2013 14:55:06] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:55:06] [30/10/2013 14:55:06] Erasing FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF...OK [30/10/2013 14:55:06] WARNING: Erasing Error (0x24) at 0x000000420000 is Ignored. Erase continues. [30/10/2013 14:55:06] WARNING: Erasing Error (0x24) at 0x0000004E0000 is Ignored. Erase continues. [30/10/2013 14:55:06] Completed in 00:00:08.265 (Average Transfer Rate: 31717.36 kB/s) [30/10/2013 14:55:06] [FINISH OPERATION_ID = DCC_ERASE_MEMORY] [30/10/2013 14:55:21] [START OPERATION_ID = RESURRECT] [30/10/2013 14:55:46] Open serial port...OK [30/10/2013 14:55:46] Connecting to the RIFF Box...OK [30/10/2013 14:55:46] Firmware Version: 1.37, JTAG Manager Version: 1.54 [30/10/2013 14:55:46] Selected Resurrector: [Samsung S5260 V1.00] [30/10/2013 14:55:46] [30/10/2013 14:55:46] Connecting to the dead body...OK [30/10/2013 14:55:46] Detected dead body ID: 0x07926F0F - CORRECT! [30/10/2013 14:55:46] Set I/O Voltage reads as 3.02V, TCK Frequency is RTCK [30/10/2013 14:55:46] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [30/10/2013 14:55:46] [30/10/2013 14:55:46] Resurrection sequence started. [30/10/2013 14:55:46] Establish communication with the phone...OK [30/10/2013 14:55:46] Initializing internal hardware configuration...OK [30/10/2013 14:55:46] Uploading resurrector data into memory...OK [30/10/2013 14:55:46] Starting communication with resurrector...OK [30/10/2013 14:55:46] [30/10/2013 14:55:46] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) [30/10/2013 14:55:46] Selected Resurrection Data for the NAND Chip with Page size = 2KB [30/10/2013 14:55:46] [30/10/2013 14:55:46] Flashing the dead body...OK [30/10/2013 14:55:46] Resurrection complete! [30/10/2013 14:55:46] [FINISH OPERATION_ID = RESURRECT] [30/10/2013 15:04:48] ------------------------------- JTAG Manager Session Closed ------------------------------- |
