Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-06-2013, 15:15   #1 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
s5302 repair problem
finally i got pass for dump (thank's to babak)
now when i m try to write dump to phone then i face some problem
problem's are :
when i am try to write dump using s5300 dll then it will showing error like :
Detected an Initialized FLASH1 Chip, ID: 0x0000/0x0015 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0000/0x0015 (SJS00M, 0x000000100000 Bytes = 1.00 MB)
ERROR: Main data file size is less than requested to flash to main.
when i am trying with s5301 dll then it will stop on
Resurrection sequence started.
Establish communication with the phone...
Old 09-06-2013, 20:04   #2 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Please Unselect "Auto Full Flash Size"....
Then Select Size (512mb)
Uncheck "Image file is Used xxxxxxxx)
Press "Write"
Read Manaul here : RIFF JTAG Box FAQ - JTAG Manager - DCC Read/Write TAB
Old 09-07-2013, 07:07   #3 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
Originally Posted by BABAK NURI View Post
Hi
Press "Write"
as per your instruction :
with s5300 dll :
Connecting to the dead body...OK
Detected dead body ID: 0x07B3617F - IGNORED!
Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x20010000000000000000000020000000
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...FAILED
ERROR: No response from the RIFF Box.
with s5301 dll :
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.37, JTAG Manager Version: 1.51
Selected Resurrector: [Samsung S5301 V1.0.4793.1616]
Detected dead body ID: 0xFFFFFFFE - IGNORED!
Set I/O Voltage reads as 1.80V, TCK Frequency is 8 MHz
Settings Code: 0x20010B00000000000000000020000000
plz if you have li'l time then see it remotely
phone history : phone comes in my hand on hang on start up
i tried to flash with Odin
battery was discharged so i used power clip
suddenly power clip stop working (may be loos connection on power clip to power wire or bad soldering )
now phone not able to going on download mode
Old 03-15-2014, 09:38   #4 (permalink)
gul_hassan528's Avatar
Member: 420821
Sonork: 100.1603493
Thanks Meter: 731
i need pasward too...........................
Page generated in 0.12740 seconds with 8 queries
