07-01-2013, 00:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: syria Age: 46
Member: 257716 Status: Offline Sonork: 1650684 Thanks Meter: 57 | s5560 help Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. wher i resurrection with 5560i boot ok but then damge boot when i flashed please riff team help with this |
07-05-2013, 01:07 | #8 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
For First,Please Post Full Log Then,Current dll Work Properly and not Have Any Bug...(Already Tested) Anyway,Plz Double Check Solderd Wires, Connect USB and Power Supply or Check With only USB,,,Also Check With Only Power Supply and Hold Power key | |
07-05-2013, 01:16 | #9 (permalink) |
Member: 257716 Status: Offline Sonork: 1650684 Thanks Meter: 57 | thx to help when i repair with 5560i the phone go to downloading mode when i repair with s5560 Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
