10-21-2012, 11:39 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: 90-region Age: 39
Member: 1246378 Status: Offline Thanks Meter: 123 | S5560 boot repair error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! WARNING: Embedded I/O Voltage is overriden to 3.30V Set I/O Voltage reads as 3.29V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. Last edited by ganjbek; 10-21-2012 at 11:47. |
10-22-2012, 00:08 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Quote:
1-Check Soldered Wires 2-Connect Power supply then press and keep power on key or 2-Connect Power Supply and Usb Cable 3-Speed 4 or 6 or 8 Mhz at TCK......(Not 1mhz at RTCK Speed) ... S5560.dll Work Perfectly and not have any bug....Tested By many User | |
10-22-2012, 06:07 | #6 (permalink) |
Member: 1246378 Status: Offline Thanks Meter: 123 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. I checked all the wires 6-8 MHz no result can be a model S5560i dll need Last edited by ganjbek; 10-22-2012 at 06:15. |
10-22-2012, 13:30 | #7 (permalink) |
Member: 1246378 Status: Offline Thanks Meter: 123 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560i V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
10-23-2012, 01:12 | #8 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Can you tell me about phone history? You can't repair s5560 via "i" dll -- Can you contact me via sonork with conected phone to Riff-Box...??? |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
10-23-2012, 13:30 | #9 (permalink) | |
Member: 1246378 Status: Offline Thanks Meter: 123 | Quote:
connection with BP response I can get in contact with you my time zone +5 (9:00 -18:00) I will at this time | |
10-23-2012, 13:37 | #10 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
There is big chance that You have some HW problem on that board. My suggestion is, check PCB carefully for cracks and water damage. As I could see from the logs, PCB has developed some problem with RAM, so it could be cold soldering or PCB cracks. | |
The Following User Says Thank You to legija For This Useful Post: |
10-24-2012, 10:59 | #11 (permalink) | |
you're right HW problem on that board. maybe Thanks I look definitively | |
