07-01-2011, 10:10 | #4 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 49
Member: 58685 Status: Offline Thanks Meter: 7 | s5560i help me please S5560i boot dead. connection is true but : riff Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Samsung S5560] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 2.98V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. please help me !!!!!!!!! |
07-01-2011, 11:37 | #6 (permalink) |
Member: 58685 Status: Offline Thanks Meter: 7 | I updated. still same Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Samsung S5560] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OKFAILED Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. ERROR: No response from the DCC Loader. Terminating. |
07-06-2011, 16:45 | #8 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | samsung s5560i boot repair? hi mr leglija. Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OKFAILED Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. ERROR: No response from the DCC Loader. Terminating. Connecting to the dead body...OK Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Model selected: SAMSUNG - Samsung S5560 Detected dead body ID: 0x07926F0F how proced to repair ? |
07-13-2011, 11:17 | #10 (permalink) |
Freak Poster Join Date: Mar 2002 Age: 46
Member: 10011 Status: Offline Thanks Meter: 46 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Samsung S5560] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 2.98V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 400 kHz] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OKFAILED Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. ERROR: No response from the DCC Loader. Terminating. I tried with every sampling rate setting available, and still getting this. On the sticker under the battery it says it's an s5560i not s5560. Could this be the reason of a failed resurection? TIA d3m0n |
07-14-2011, 21:25 | #11 (permalink) |
Member: 188484 Status: Offline Thanks Meter: 117 | not work mister leglija .I have one samsung s5560i good .I try read dump but ID detected read not work.procesor is broadcom bcm 2133 it the same s5560 but not repaired.I need your help. alunecosu_hd yahoo mesenger id |
07-14-2011, 21:39 | #12 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Yes, "i" version has different NAND config, same as in S5260. I think in day or two there will be new DLL. You should contact me via Sonork, since I dont use anything else, besides ICQ and Sonork. |
07-15-2011, 22:52 | #14 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | |
The Following User Says Thank You to legija For This Useful Post: |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
Contact Service Repairer 1.2 by Bartek | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2011 09:00 |
F_loaders.bin and Boot.bin .. . | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-29-2001 14:49 |
Phone not respond! (Load boot data) Need a help ! | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-23-2001 02:10 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
