07-18-2013, 13:32 | #1 (permalink) |
Insane Poster Join Date: Aug 2010
Member: 1360145 Status: Offline Thanks Meter: 12 | S5570i dead I erased flash chip and resurrected but stopped in 28%. Here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S5570i V1.0.4476.11820] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 2.99V, TCK Frequency is 2 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x3E (0x05481A <> 0x042000) |
07-19-2013, 01:32 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi inambo_007 Please Try This : 1-Connect Power Supply And USB Cable 2-Press "Resurrect" --- Also You can write full dump,Of course no need "take phone in drower for 24-48 hours" D: |
07-19-2013, 04:09 | #4 (permalink) | |
Member: 1360145 Status: Offline Thanks Meter: 12 | Quote:
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S5570i V1.0.4476.11820] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x25010009000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF ERROR: DCC Loader has reported Error Code = 0x3E (0x05481A <> 0x042000) Tried many combinations on RTCK speed Please provide solution... | |
07-19-2013, 06:59 | #5 (permalink) |
Freak Poster Join Date: Mar 2011 Location: in BIGSERVER
Member: 1542932 Status: Offline Sonork: 100.1621006 Thanks Meter: 53 | i try many times,when dump write complete phone not works. after 1-2 days works very fine. i test in 512mb flash chips only. latest update i done s5360 two days ago. team have to test also this. |
07-19-2013, 08:44 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi BIGUNLOCKSERVER What's a Point...??? You know why...? Sure,Next Time i'll be test,But I See Many Time Need Reheat or Reball PMIC in pcb,So,next time you test it too Thanks |
