11-29-2012, 15:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | s5830 Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5830 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x503C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
11-30-2012, 04:36 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please explain about phone history... Also maybe you have hw fault --- if you sure about HW,Try This 1-speed at 6MHZ in TCK 2-remove usb 3-connect power supply 4-press "Resurrect" and Quickly press and keep "Power on key" or 1-connect usb cable 2-input battery 3-press "resurrect" |
