12-25-2013, 12:22 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: TURKEY/KAYSERİ Age: 45
Member: 60931 Status: Offline Thanks Meter: 26 | s5830ı dead boot repair Error Code = 0x30 (0x000000). Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung S5830i V1.0.4476.13359] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x30 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000 |
12-25-2013, 23:00 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi 0x30 Error have 2 reason.... 1-Phone not powered or unstable power or bad wires 2-damaged or bad Nand chip so try this: Set TCK Speed at 4MHZ or 1MHZ (not RTCK ) 1-resloder all jtag wires carefully 2-connect USB To Phone and PC 3-Connect Power Supply to phone 4-Press Resurrect |
12-26-2013, 13:53 | #3 (permalink) |
Member: 60931 Status: Offline Thanks Meter: 26 | S5830I 0x30 Error Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 1 MHz Settings Code: 0x17010600000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Reading FLASH1 address space from 0x000000000000 to 0x00001FFFFFFF FULL BACKUP OK 528 MB BOOT REPAİR EROR 0X30 %7 STOP |
