08-15-2012, 13:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: across in the archipelago
Member: 1170687 Status: Offline Thanks Meter: 30 | S5830 no imei no baseband.. need help! first try always error and i ignore it.. Code: [8/15/2012 6:04:48 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [8/15/2012 6:04:48 PM] [8/15/2012 6:04:48 PM] Current Settings: [8/15/2012 6:04:48 PM] ----------------- [8/15/2012 6:04:48 PM] Address: 000000000000 [8/15/2012 6:04:48 PM] Length: 000020000000 [8/15/2012 6:04:48 PM] Address Space: ROM1 [8/15/2012 6:04:48 PM] AutoFullFlash: CHECKED [8/15/2012 6:04:48 PM] Use End Address: UNCHECKED [8/15/2012 6:04:48 PM] ECC Module Enabled: UNCHECKED [8/15/2012 6:04:48 PM] Image File is Used: UNCHECKED [8/15/2012 6:04:48 PM] Use Address as Offset: UNCHECKED [8/15/2012 6:04:48 PM] Main (CHECKED): D:\Flash files\Riffbox\Samsung s5830\s5830-RedeYeS.bin [8/15/2012 6:04:48 PM] Redu (CHECKED): D:\Flash files\Riffbox\Samsung s5830\s5830-RedeYeS.bin [8/15/2012 6:04:48 PM] [8/15/2012 7:09:01 PM] Open serial port...OK [8/15/2012 7:09:01 PM] Connecting to the RIFF Box...OK [8/15/2012 7:09:01 PM] Firmware Version: 1.32, JTAG Manager Version: 1.43 [8/15/2012 7:09:01 PM] Selected Resurrector: [Samsung S5830 V1.00] [8/15/2012 7:09:01 PM] [8/15/2012 7:09:01 PM] Connecting to the dead body...OK [8/15/2012 7:09:01 PM] Detected dead body ID: 0x303C10E1 - CORRECT! [8/15/2012 7:09:01 PM] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [8/15/2012 7:09:01 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [8/15/2012 7:09:01 PM] Settings Code: 0x64010000000000000000000020000000 [8/15/2012 7:09:01 PM] [8/15/2012 7:09:01 PM] Resurrection sequence started. [8/15/2012 7:09:01 PM] Establish communication with the phone...OK [8/15/2012 7:09:01 PM] Initializing internal hardware configuration...OK [8/15/2012 7:09:01 PM] Uploading resurrector data into memory...OK [8/15/2012 7:09:01 PM] Starting communication with resurrector...OK [8/15/2012 7:09:01 PM] [8/15/2012 7:09:01 PM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) [8/15/2012 7:09:01 PM] [8/15/2012 7:09:01 PM] Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF [8/15/2012 7:09:01 PM] WARNING: Programming Error (0x24) at 0x00000DA80000 is Ignored. [8/15/2012 7:09:01 PM] WARNING: Programming Error (0x24) at 0x000011440000 is Ignored. [8/15/2012 7:09:01 PM] WARNING: Programming Error (0x24) at 0x00001D600000 is Ignored. [8/15/2012 7:09:01 PM] WARNING: Programming Error (0x24) at 0x00001E500000 is Ignored. [8/15/2012 7:09:01 PM] WARNING: Programming Error (0x24) at 0x00001F280000 is Ignored. [8/15/2012 7:09:01 PM] Completed in 01:04:10.172 (Average Transfer Rate: 140.43 kB/s) [8/15/2012 7:09:01 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] Code: [8/15/2012 7:26:56 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [8/15/2012 7:26:56 PM] [8/15/2012 7:26:56 PM] Current Settings: [8/15/2012 7:26:56 PM] ----------------- [8/15/2012 7:26:56 PM] Address: 000000000000 [8/15/2012 7:26:56 PM] Length: 000020000000 [8/15/2012 7:26:56 PM] Address Space: ROM1 [8/15/2012 7:26:56 PM] AutoFullFlash: CHECKED [8/15/2012 7:26:56 PM] Use End Address: UNCHECKED [8/15/2012 7:26:56 PM] ECC Module Enabled: UNCHECKED [8/15/2012 7:26:56 PM] Image File is Used: CHECKED [8/15/2012 7:26:56 PM] Use Address as Offset: CHECKED [8/15/2012 7:26:56 PM] Main (CHECKED): D:\Flash files\Riffbox\Samsung s5830\s5830-RedeYeS.bin [8/15/2012 7:26:56 PM] Redu (UNCHECKED): D:\Flash files\Riffbox\Samsung s5830\s5830-RedeYeS.bin [8/15/2012 7:26:56 PM] [8/15/2012 8:00:14 PM] Open serial port...OK [8/15/2012 8:00:14 PM] Connecting to the RIFF Box...OK [8/15/2012 8:00:14 PM] Firmware Version: 1.32, JTAG Manager Version: 1.43 [8/15/2012 8:00:14 PM] Selected Resurrector: [Samsung S5830 V1.00] [8/15/2012 8:00:14 PM] [8/15/2012 8:00:14 PM] Connecting to the dead body...OK [8/15/2012 8:00:14 PM] Detected dead body ID: 0x303C10E1 - CORRECT! [8/15/2012 8:00:14 PM] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [8/15/2012 8:00:14 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [8/15/2012 8:00:14 PM] Settings Code: 0x27010000000000000000000020000000 [8/15/2012 8:00:14 PM] [8/15/2012 8:00:14 PM] Resurrection sequence started. [8/15/2012 8:00:14 PM] Establish communication with the phone...OK [8/15/2012 8:00:14 PM] Initializing internal hardware configuration...OK [8/15/2012 8:00:14 PM] Uploading resurrector data into memory...OK [8/15/2012 8:00:14 PM] Starting communication with resurrector...OK [8/15/2012 8:00:14 PM] [8/15/2012 8:00:14 PM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) [8/15/2012 8:00:14 PM] [8/15/2012 8:00:14 PM] Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF [8/15/2012 8:00:14 PM] ERROR: Reported Failure Code 0x24. Terminating at 0x00000DA80000 [8/15/2012 8:00:14 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] |
08-16-2012, 00:26 | #2 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Hi. Flash mit Odin Multiloader 4.38 with Cooper.ops and One Package Firmware,after Flash reboot in Recovery and make Wipe Data/Factory Reset and reboot,your problem solved. For IMEI+Baseband repair use anyone Samsung Tools(Z3X,SPT2). Best regards! |
08-16-2012, 01:38 | #3 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Do not want to tell you Age: 38
Member: 1538800 Status: Offline Sonork: Offline Thanks Meter: 18 | Quote:
I want to know Z3X and SPT2 which is easy to use? | |
08-16-2012, 07:37 | #4 (permalink) | |
Member: 1170687 Status: Offline Thanks Meter: 30 | Quote:
Manage to figure it out... but the error 0x24(just use other jtag tool) resurrect with riff full erase........................has an error 0x24 write S5830 redeyes.bin....has an error 0x24 flash via odin use S5830JPKA7 no need to use samsung tools its automatic baseband and imei are all good =Maybe riff can add a feature Repair just like others have= | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
