05-29-2013, 21:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: EGYPT/CAIRO Age: 43
Member: 162544 Status: Offline Thanks Meter: 17 | S5830 ram memory selftest failed Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S5830 V1.0.4860.51697] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x503C10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. ------------------------------------------------------ i tried every thing - with and without lcd - full battary - low tck from 1 to 10 mhz - wires less then 15cm - good soldering test with voltameter * p.s. it's not hardware cause other set with same condetion solved with other tool |
05-30-2013, 11:34 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Read : RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed. You Can Check With Generic dll(MSM7227) |
06-02-2013, 21:52 | #6 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Respect The Rule and wait For Answer.... Why Not Read More Explain...? Quote:
