06-05-2013, 00:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | S5830 wont conect I have made all steps. Conected USB, put battery and solder all. ------------------------------------------------------------------ Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S5830L V1.0.4676.8998] Connecting to the dead body...FAILED None is detected. ------------------------------------------------------------------ |
06-05-2013, 03:32 | #3 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Russia Age: 44
Member: 1331464 Status: Offline Thanks Meter: 206 | Connect only pcb without lcd. Connect external power to battery connector and make power key pressed during all ressurection procedure. Speed tck 1-2 mhz. All will be well. Solution tryed on a lot of 5830 5660 phones. |
06-05-2013, 21:12 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Sinaloaeshop For First Step,Please Cut "VCC".....For more than 98% No need Solder VCC Then,Please use Short Wires Also Connect Power Supply and USB,Then Press "Resurrect" Yes,Your Adapter is fine |
