04-22-2012, 01:19 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 333519 Status: Offline Sonork: 100.1620327 Thanks Meter: 16 | s5830M[Solved] Connecting to the dead body...ERROR ERROR: The RTCK Signal does not respond. my question is riff support s5830M boot repair????? the phone turns on but with s5360 logo, but no enter download mode please i need help |
04-22-2012, 10:00 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi First You Need Check With USB-JIG (Maybe Enable D/L Mode) But if Cpu Type Same As S5830(ace) You Can use This Dll for Repair Then Flash With Correct Firmware... |
04-23-2012, 21:29 | #3 (permalink) |
Member: 333519 Status: Offline Sonork: 100.1620327 Thanks Meter: 16 | i try to repair boot with s5830 model but no success, when i conect as s5360 the phone repair boot and there is a comunication, i flashed with s5830-RedeYeS.bin, the flash ends ok but the phone dosent turns on, and i try to repair boot with s5830 model but error. I dessambly the phone and the chip is broadcom BCM21552KFFBG TC1209 P21 I NEED TO KNOW how can i repair this phone |
04-23-2012, 22:01 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | WOW,,,You did write s5830 dump into s5830m.....(MSM to BCM) I Just Told You "If Cpu Is Same" "Maybe You Can use S5830.DLL"(just for Resurrect) Anyway.......it's a Diffrent.....Do you Have read full Flash before Resurrect...? S5830M And S5830i have a Same Cpu....Maybe you can resurrect with S5830i.dll(Only Resurrect---not write full dump-5830i dump) Please Don't Try AnyThing If you don't Know What is this... |
04-23-2012, 22:26 | #5 (permalink) | |
Member: 333519 Status: Offline Sonork: 100.1620327 Thanks Meter: 16 | Quote:
04-23-2012, 22:29 | #6 (permalink) | |
04-23-2012, 22:37 | #7 (permalink) |
Junior Member Join Date: Feb 2009 Location: colombia, cartago
Member: 968754 Status: Offline Thanks Meter: 0 | support dead flash riff s5830m I came a s5830m still not starting, click on resurrection gave him and I wanted to receive free flash because it does not goes into download mode, then the flash flashe a riff (s5830-full_backup) select "auto size fullflash "and I clicked on" write flash ". now comprises only black screen. I wonder if I can help with any tutorials for flash and get revived. translated with google! |
04-23-2012, 22:40 | #8 (permalink) |
Member: 968754 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.42 Selected Resurrector: [Samsung S5830i V1.0.4476.13359] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x24010000000000000000000000000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Resuming write FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF on 0x000008E40000 Completed in 00:23:06.844 (Average Transfer Rate: 389.86 kB/s) |
04-24-2012, 12:47 | #9 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi S5830i.dll Already at support area Goto "Box Services".....Click "Check For Update"....Search and find and Download DLL Also You Can Read Full Dump From Working Phone With "DCC Read/Write" Page But First Try Repair With S5830i.dll......It's should be work |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
04-24-2012, 21:36 | #11 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Great..... Please Read Full Dump from S5830m,If You Can And You Have a Free Time... I Think You Can Flash "M" Model By "i" Firmware....(one user report to me ,that's possible) Anyway,...If you want read dump,please read this with "M" Firmware |
