03-18-2013, 21:27 | #1 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 389723 Status: Offline Thanks Meter: 2 | S6102 Dead boot & after repair still no boot >> plz help i've S6102 & its flashed by S6802 by wrong now its dead boot & after tried to repair boot by riff still no download mode !! Here is the log : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S6102 V1.0.4640.6533] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! I've tried many Resurrection speed also |
03-18-2013, 21:56 | #2 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Kz Age: 58
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | hi. resurrector for s6102 does not consist some data. so, solution is very simple- make resurrect as s5360 and then next step - again resurrect as s6102. After that procedure should put phone in dl mode manualy (you' ll get white screen and it need make finger manipulation as blind musicant) and flash with odin - pit, pda, modem, csc - don't reflash boot via odin. you will be surprised - now phone get full alive condition. B.R. Last edited by Nicolayer; 03-18-2013 at 22:06. |
03-19-2013, 09:06 | #5 (permalink) |
Member: 389723 Status: Offline Thanks Meter: 2 | Yes .. After made special combo usb phone is in flash port Now its alive agaaaaaaaaaaaaaaaaaaaaaaaaaaain you're da best of the best man & even my words not enough to thanks you thanks again |
03-20-2013, 07:01 | #7 (permalink) |
Insane Poster Join Date: Apr 2007 Location: IR.Tehran
Member: 491308 Status: Offline Sonork: 100.1624581 Thanks Meter: 8 | use this method 100% solve test by me on many samsung 6120 phone 1- erase your phone 2-resurrect after this use vol- + home + power if not working use usbjig to force it to inter download mode after write firmware phone power on but no IMEI for this problem root your phone and repair IMEI by Z3X or other tools |
03-20-2013, 19:13 | #8 (permalink) | |
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | Quote:
For why??? for revive S6102 enough only RIFF box and clear head | |
