07-22-2013, 11:54 | #1 (permalink) |
Registered User Join Date: Jul 2004 Location: nonthaburi thailand Age: 51
Member: 73464 Status: Offline Thanks Meter: 26 | S6102 Repair Boot error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S6102 V1.0.4640.6533] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. i try to change to 5 8 10 mhz STILL same Error please help |
07-22-2013, 23:05 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi "ERROR: RAM memory selftest failed." Error usually Mean Damaged eMMC But,Please Read: RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed. Please Goto DCC Read/Write Page,Then Try Read 1 mb With any all Dll based on new BCM or use Generic dll |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-23-2013, 07:54 | #3 (permalink) | |
Member: 73464 Status: Offline Thanks Meter: 26 | Quote:
Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x25010009000000400000000001400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. same | |
