08-05-2013, 05:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | S6500d Resurrection Complete.. But phone is still dead.. Unit: GT- S6500d Problem : Deadboot According to the owner, she's just playing game when handset turned off.. Tried connecting to pc but not detected. Assumed deadboot.. Tried with JTAG (RIFF) Resurrected complete but handset is still dead.. Need idea from here.. Logs: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S6500D V1.0.4800.45222] Connecting to the dead body...OK Detected dead body ID: 0x106040E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00M, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body...OK Resurrection complete! |
11-16-2013, 14:48 | #3 (permalink) |
Junior Member Join Date: Jan 2008
Member: 692339 Status: Offline Thanks Meter: 0 | Samsung S6500D dead boot repair done Hello Can you explain wich component do you checked ? I have a simillar problem in riff : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [Samsung S6500D V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x106040E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 9 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (SJS00M, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body...OK Resurrection complete! |
11-16-2013, 14:59 | #4 (permalink) |
Member: 692339 Status: Offline Thanks Meter: 0 | I can't turno on the phone, can't into the recovery or anything. The phone not recognized in pc and not responde to the charger. Flashing on riff resurrection compleate - post above. However, I noticed that the hold the POWER button speaker phone it sounds like getting single voltage pulses. Battery is full charged. |
