12-15-2013, 11:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: LIKE MOBILE SOFTWARE
Member: 1084993 Status: Offline Sonork: 100.1617420 Thanks Meter: 641 | s6802 boot repair problem i try flash odin canot flashing then phone suddenly dead i try boot repair come this error note i try to other jtag box no response Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [Samsung S6802 V1.0.4690.61628] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
The Following User Says Thank You to redrose2009 For This Useful Post: |
12-15-2013, 12:24 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi For First You must know 800khz at RTCK not stable speed and can't work Then Please Read : RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
05-07-2014, 08:52 | #3 (permalink) |
Major Poster Join Date: Oct 2005 Location: india
Member: 191089 Status: Offline Thanks Meter: 8 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung S6802 V1.0.4690.61628] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0000/0x0015 (SJS00M, 0x0000E9000000 Bytes = 3.64 GB) Detected an Initialized FLASH2 Chip, ID: 0x0000/0x0015 (SJS00M, 0x000000100000 Bytes = 1.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 3.64GB Flashing the dead body...OK Resurrection complete! |
