08-01-2013, 00:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Oued zenati Algeria Age: 44
Member: 266158 Status: Offline Sonork: 131654654654 Thanks Meter: 198 | s8530 ...FAILED Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung S8530 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x7FFFFFFF - IGNORED! Set I/O Voltage reads as 2.78V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating.FAILED |
08-02-2013, 07:11 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Why You Did Disable ID CODE Check??? You Have Bad ID From Phone,,,It happen Usually For Bad Soldering Jtag Wires Also possible Damaged CPU Please remove all jtag wires,Then Clean Pinout on PCB 1-Try Soldering Again 2-Use Power Supply 3-Use USB Cable 4-Try For Resurrect |
