10-08-2013, 08:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Offline Thanks Meter: 67 | s8600 still dead after resurec pls.help me help me how to write the full dump. history of phone:ALWAYS RESTART. the i try to flash to in multiloader but when start flashing error ing writing frimware now phone cant download mode.. pls help me |
10-08-2013, 16:55 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | How dead is dead? Maybe Qualcomm Driver request visible? Check device Manager... http://forum.gsmhosting.com/vbb/f818...e-3-a-1610764/ Also be sure, battery is NOT empty... Best Regards |
10-08-2013, 23:56 | #7 (permalink) | |
Member: 1190283 Status: Offline Thanks Meter: 67 | Quote:
cant download mode......... battery already full charge br. | |
10-09-2013, 02:52 | #8 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | You could try to READ Memory... to be sure it is not empty or something goes wrong... After you have read 4 GB... open HEX Editor... check if you can find text Qualcomm... Also be sure you have no M410K or M410S or NOT for Sale device... Check label under battery... Then you could try again Resurrection Button... But this time if not Download Mode can be activated... Check Windows device manager if other Driver is requested or allready Qualcomm driver visible... You can find also other 4 GB dump via Google... Also possible... if you are 100 % sure you have all things tried... then maybe Hardware problem... Btw. I have not tested to write 4 GB via RIFF.... Also my solder skills are not high enough for S8600... Check again other Threads about S8600 reanimation via Riff... No idea if proper answer somewhere... Good luck. Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
10-09-2013, 03:59 | #10 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Are you sure it is good idea to erase? Maybe check first the other S8600 Threads... http://forum.gsmhosting.com/vbb/9731611-post3.html Best Regards |
