01-05-2014, 16:37 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: KRJ
Member: 993718 Status: Offline Thanks Meter: 91 | samsung ace s5830 WARNING: Programming Error (0x24) i have s5830 on working condition wrongly i flash it with s5830i firmware after this phone show download mode again i flash it with it's og flash with odin but it's show big partition size then i full erase with riff jtag and write full dump now phone starting but stuck on samsung logo this error comes when erase and write file any solution then help me here is screen shot Erasing Log [START OPERATION_ID = DCC_ERASE_MEMORY] Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung S5830 V1.0.4860.51697] Connecting to the dead body...OK Detected dead body ID: 0x303C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x05010000000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x000003C40000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x000004AC0000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00000D540000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00000EF40000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x000016F00000 is Ignored. Erase continues. Completed in 00:00:15.735 (Average Transfer Rate: 33319.86 kB/s) [FINISH OPERATION_ID = DCC_ERASE_MEMORY] |
The Following User Says Thank You to dev.saini For This Useful Post: |
01-05-2014, 20:45 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Is Normal this error No need dump flash Erase phone again Ressurect Insert jig for put download mode Flash via Odin Imeir repair 100% tested by myself. |
The Following User Says Thank You to toninhosantos For This Useful Post: |
01-06-2014, 05:27 | #3 (permalink) |
Member: 993718 Status: Offline Thanks Meter: 91 | Not working for me when i flash with odin odin show this error Download Start... <0> Create File... <1> StartThread Detected : 0 <2> StartThread Detected : 1 <3> StartThread Detected : 0 <4> StartThread Detected : 0 <5> StartThread Detected : 0 <6> StartThread Detected : 0 <7> StartThread Detected : 0 <8> StartThread Detected : 0 <2> setup connection... <2> odin mode.. check plcatform verification. <2> VerifyPlatform:V0, P0,R0 <2> START!!! <2> set download environment. <2> big partition size!! <2> big partition size!! <2> big partition size!! <2> big partition size!! <2> big partition size!! <2> big partition size!! <2> mibib download.. and stuck here here is screen shot |
