02-11-2013, 11:55 | #6 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung B119 V1.00] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x220B10E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x62010000000000000000000001000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip, ID: 0x0000/0x0000 (16MB) ERROR: Main data file size is less than requested to flash to mai im try pst but sat is dad im try to riff but this error wbr ; tejaram |
02-11-2013, 12:14 | #7 (permalink) | ||
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Your file size Quote:
Okai.. What's ur fone status before flash? | ||
02-14-2013, 21:22 | #9 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Don't Select Samsung B119 Because It Has 8MB. | |
03-21-2013, 14:17 | #10 (permalink) |
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung B139 V1.00] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x220B10E1 - IGNORED! WARNING: Embedded I/O Voltage is overriden to 3.30V Set I/O Voltage reads as 3.32V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x24010000000000000000000001000000 WARNING: Reset Override to: [No RESET] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip, ID: 0x0000/0x0000 (16MB) ERROR: Main data file size is less than requested to flash to main. wbr tejaram |
03-21-2013, 14:24 | #11 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
