05-25-2013, 11:43 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: shimoga Age: 40
Member: 781262 Status: Offline Thanks Meter: 90 | samsung c6712 after dead boot repair hangs at samsung logo |
05-26-2013, 09:48 | #3 (permalink) | |
Freak Poster Join Date: May 2013 Location: IRAN__SHIRAZ
Member: 1933631 Status: Offline Sonork: 100.1618169 Thanks Meter: 52 | Quote:
you should to erase your phone with riff box after that resurrect the phone 100% became ok br majidinia | |
05-26-2013, 11:10 | #4 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
This is usually HW Problem,Check Phone History Via Your Client | ||
08-06-2013, 00:37 | #8 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | First: Erase the NAND flash Second: Do the normal process of resurrection Third: Use the USB jig to enter donwload mode. Fourth: Install any firmware Fifth: Repair IMEI with Z3x Post results. Hope this helps. |
08-06-2013, 00:45 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | its hardware foult check battery connector way sure its hardware problem not software chek battery way if u got no supply in connector chek from other board make bc jumper if u got all bc connection working than rehot cpu. |
10-20-2013, 09:43 | #12 (permalink) |
No Life Poster Join Date: Nov 2011 Location: INDIA
Member: 1697041 Status: Offline Sonork: 1609691 Thanks Meter: 67 | i have i set in this condition boot is damaged repair by riff and wite full dump but set hang on logo and reflash many time all flash file but condition is still anybody expert pls solve my problem...................?????????????? |
11-19-2013, 07:13 | #13 (permalink) |
Freak Poster Join Date: May 2012 Location: india \westbengal / katwa Age: 37
Member: 1762926 Status: Offline Sonork: 1619564 Thanks Meter: 83 | Posted by ALI MAJIDINIA View Post you should to erase your phone with riff box after that resurrect the phone 100% became ok br majidinia i have already this one but no result in first post i have explained it .................................................. ..... |
