Galaxy tab I have a samsung p1000 I repair the boot with the riff and now the box turns on and remains on samsung GALAXY TAB. I flashed it but until then make m ^ me something and I wanted to know if there has a solution. please do help NEED FOR |
Flash the tab with odin. After flashing probably need to install the dbdata manual;) |
Galaxy tab p1000 I need the firmware samsung GALAXY TAB P1000 which is the file or TAR file PDA, MODEM, CSC if you helped me |
P1000 Help needed . I have recieve this phone in bricked condition .. customer said that after update by Odin , it went completely dead . so i did resurrection . but still bricked , then i did with Tiked Linux + Goblin .. but still same bricked . Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.22 Selected Resurrector: [Samsung Galaxy Tab] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! I have p1000 not the M version . will i required full dump ? help is urgently needed . |
Any help .......................... |
hmmm:( i had bricked P1000 in my office. Ressurection was good, and flashing after with Odin 1.7 was no problem. Can you start the download mode? |
after Ressurection..can you put your p1000 in download mode by hold volumn down+power on? |
I am sorry guy .. Battery was dead Flat .. After charging for 4 hours via desktop charger .. Phone is now going to Download mode .. so i decided to flash with European firmware with its Pit + PDA + CSC ... Flashing went successful but phone Powered ON in Recovery mode .. :( Do i decided again to flash via Arabic firmware with its PITS .. don't know what the fcukk thing happen .. Now its completely dead again ... Well i'll Do resurrect again tomorrow but whats the correct proceedure to FLash this Dam phone ? |
Its very easy You can flash european version after flashing the phone goes in recovery mode to install the dbdata. If this was not possible flash the dbdata manually in PDA-Section. After flashing dbdata hold power an volume up to restart the tab. If the tab restarts let of the power button and hold the volume-up to go into manual installation mode. Now the Tab should install the dbdata manually and make an restart. Then it should boot normaly. If you need dbdata for this tab i can send you a download-link;) Note if you flash the european version flash only the OXAJK5 or XXJK5. This versions are the latest officially Samsung Versions. And as i know they have no signed bootloader. All newer versions had new signed bootloader so after flashing you can't downgrade anymore (i don't know if you can downgrade after ressurecting with RIFF again;)) |
sure send me db data ... what the hell is this . i dont know about it :D also please provide me the link of the versions you are saying |
Gt p1000 galaxy tab I have problems with the samsung p1000 I repair the boot with RIFF BOX it and I flacher but still does not work. I wanted to know if there is another solution for the repair to wane and with the soft boot |
hello ? you were sending that dbdata ? |
Link to the dbdata: http://rapidshare.com/files/443561834/dbdata.rar The link to the firmware will follow asap. No the file is in Upload;) And use odin3 v1.7 to flash the tab dbdata is the same as csc. When you don't install the dbdata you can't see correct informations of firmware in the tab. The tab will hang on Galaxy Tab when start the tab. This error come when you flash 1-File-Firmware. |
Here the Firmwarefile: http://rapidshare.com/files/443564612/P1000OXAJK5.tar |
