01-21-2016, 12:43 | #1 (permalink) |
Junior Member Join Date: May 2007
Member: 516691 Status: Offline Thanks Meter: 2 | Samsung GT-I8190n - full dump via RIFF Could you help me with my Samsung GT-I8190n phone on Android 4.1.2, please? I need to make a JTAG full dump by RIFF BOX. I have already connected phone PCB via JTAG. All I have right now is: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190N V1.0.5053.48340] Connecting to the dead body...OK WARNING: Connection via USB failed with Code: 0xC000FF01 Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Settings Code: 0x0600000E000000000000000008000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Any help, please? Cheers from Poland. |
01-21-2016, 13:04 | #2 (permalink) |
Member: 516691 Status: Offline Thanks Meter: 2 | Something new when I try TCK communication... ------------------------------------------------------------------------------- Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190N V1.0.5053.48340] Connecting to the dead body...OK Set I/O Voltage reads as 1.80V, TCK Frequency is 4 MHz Detected dead body ID: 0x4BA00477 ------------------------------------------------------------------------------- Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x05 bits Device on TAP #1: ID = 0xFFFFFFCF, IR Length = 0x01 bits Device on TAP #2: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #3: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #4: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #5: ID = 0x000000FF, IR Length = 0x01 bits Total IR length: 0x000A bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x4BA00477: Generic CORTEX-A9/A15 Core Based Target ------------------------------------------------------------------------------- Halting target...OK STATUS: Target is halted. R0 = 0x00000001 R6 = 0x00000000 R12 = 0x00000000 R1 = 0x00000000 R7 = 0x00000001 R13 = 0x14105F54 R2 = 0x00000000 R8 = 0x90017040 R14 = 0x00000000 R3 = 0x00000000 R9 = 0x00000000 R15 = 0x90017040 R4 = 0x00000001 R10 = 0x00000000 CPSR = 0x00000093 R5 = 0x00000000 R11 = 0x00000000 ------------------------------------------------------------------------------- Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190N V1.0.5053.48340] Connecting to the dead body...OK WARNING: Connection via USB failed with Code: 0xC000FF01 Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 2 MHz Settings Code: 0x06000705000000000000000008000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035 ERROR: Auto FullFlash to be used only for FLASH memory. Terminating. ------------------------------------------------------------------------------- Maybe I am on the good way but I missed something... Thanks in advance. Last edited by mic1986; 01-21-2016 at 13:13. |
02-01-2016, 14:54 | #5 (permalink) |
Member: 516691 Status: Offline Thanks Meter: 2 | any one please help me? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK WARNING: Connection via USB failed with Code: 0xC000FF01 Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035 ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 0B I don't know why RiFF told me that eMMC chip have 0B capacity. Phone work normally so maybe the problem is in settings... |
