11-07-2013, 12:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Manhuaçu/MG/BR/
Member: 251218 Status: Offline Thanks Meter: 39 | Samsung GT-S5830i/c - Uploading resurrector data into memory...FAILED Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [Samsung S5830i V1.0.4476.13359] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. Solution? |
11-30-2014, 14:16 | #4 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 24 | samsung s5830i came to me in working condition the fault was when make a call the dail pad does not appear so i try to flash with odin with 5830i file the flash even did not start i get a message failed now no dl mode even with jig when on the set just a light comes thats all. i try with riff box but could not get connect and get id the mobile does not get connected with riff box any solution pls. |
