07-22-2012, 15:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Visakhapatanam, India
Member: 1687888 Status: Offline Thanks Meter: 36 | P1000 stucks at samsung!!! And second one which one stucked at samsung i tried each and everything on it i reconstructed it!! Sucessfully reconstructted and i tried flashing with several firmwares but still same i posted several posts!! http://forum.gsmhosting.com/vbb/f606...msung-1469399/ http://forum.gsmhosting.com/vbb/f606...y-tab-1454688/ Tried all of them but still same i need a big help from you guyz im new to riff i bought yesterday only so please give me full procedure it just stucks at samsung!! pLease help me Br..., |
07-22-2012, 21:08 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi First you need make sure about phone model...... some user have a different type of galaxy tab...like P1000N..P1000L...P100...I800...etc ------------- Then,You Need Flash phone with latest 2.3.3 firmware...Also You Need Use "PIT" File.. p1000 Have a some Pit..So,You Need Check with all "Pit" ------------- If still have a problem, Try This: 1-Erase Full Flash Size By RIFF-Box( It's 512MB) 2-Resurrect phone With Select All Other Option(Germlin-Recovery-Linux Kernel) 3-Flash phone by Odin..(You need 3 parts firmware + P1_add_Hidden.pit)..Don't Forget Checked "Repartition" 4-Repair EFS Content By Riff plugin or ADB Command ----------- Or: 1-Erase full flash size 2-Write Good Working Dump File 3-Repair Imei |
07-23-2012, 10:48 | #4 (permalink) | |
Member: 1687888 Status: Offline Thanks Meter: 36 | Quote:
How to erase full flash size 512 MB bro please help me im not expert in this box i bought this box day before yesterday!! | |
07-23-2012, 23:07 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You can search on forum ------ anyway goto DCC Read/Write page...select auto full flash size,uncheck "main" and Press erase |
07-23-2012, 23:48 | #6 (permalink) |
Member: 1687888 Status: Offline Thanks Meter: 36 | bro then what about other things Explain all the things sir how to write efs file and where ill get find that file and what about full backup ? i cant find anything please help me sir im really a big noob for this box :-( |
07-24-2012, 04:30 | #8 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | I have this file, fix much P1000 and M180s hang logo after repair boot. Use odin, choose as PDA and flash. dbdata.rfs.tar |
The Following 3 Users Say Thank You to ..::Thanh_gsm::.. For This Useful Post: |
07-30-2012, 17:53 | #9 (permalink) | |
I did each and everything what you have say sir i erased phone i flashed with several firmwares with several pits I erased phone wrote 3 of DUMP file which exist in support area still the damn ****ING phone stucks at samsung i wrote dbdata.tar file also still stuck at this please anyone HELP ME!!! Really stucked at this one!! | |
07-30-2012, 18:04 | #10 (permalink) |
Member: 1687888 Status: Offline Thanks Meter: 36 | And i Saw that When ever i solder and connect to RIFF box The CPU Gets heat it self And wen i connect to cable too it will get heat!! Wen its get late it will heat the whole BOARD!! Please help me anyoNE this phone reaLLY *****SSSS!!!! |
07-30-2012, 18:06 | #11 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | After writing dbdata.rfs.tar of course you must reflash phone normal way ! Means you have to have - Files : Code, CSC & Modem - Pgm : Odin3_v1.31.exe, file Odin3.ini & Pit. - Driver : SAMSUNG_USB_Driver_for_Mobile_Phones_v1.3.400.0.ex e Settings as on the picture. Of course Hardware must be good to succeed. But if we say that your hardware is bad, arrogant people will edit my post again BR Max_B |
07-30-2012, 18:09 | #12 (permalink) | |
yeah i did each and everything AFter dbdata.rfs file i flashed with several firmwares reconstructted MR babak NURI sir helped me a lot !! But still stucked!! | |
07-30-2012, 18:26 | #13 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Personnaly I don't think that overheating CPU could be fixed via software from start. And all freezing at SAMSUNG logo phones I had were not SW faulty ! SAMSUNG freezed = Hardware fault However if the blue line stops at initial, then you can try to fix boot. But if set hanged without having played with, then hw is damaged. BR Max_B |
SW ASIC MISHATCH at 5110 | jonwillow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-29-2001 15:30 |
Something special at http://westerna.org | westerna | GSM Mobile Links | 0 | 09-14-2001 10:29 |
Just have a look at ... | frenchcortex | GSM Mobile Links | 0 | 08-06-2001 18:54 |
How can I use AT command control Nokia6110?Help me! | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-15-2000 07:35 |
Programmeing tools at www.cellularrepairs.co.uk | dave | GSM Mobile Links | 0 | 09-09-1999 20:22 |
