Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 11-23-2013, 08:20   #1 (permalink)
fertxter's Avatar
Member: 1344255
Sonork: 1659066
Thanks Meter: 131
Exclamation Samsung GT-S7562 dous Samsung logo only done by Riff Box
Status of unit Samsung logo or Restating only
Action
Flashing on odin and Z3x with one file flashing or full file flashing no lock
Tools
Riff box
Dump file
Logs
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.37, JTAG Manager Version: 1.55
Selected Resurrector: [Samsung S7562 V1.0.4816.57076]
Connecting to the dead body...OK
Detected dead body ID: 0x106230E1 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x20010000000000000000000020000000
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (A00SJJ, 0x0000E9000000 Bytes = 3.64 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (A00SJJ, 0x000000100000 Bytes = 1.00 MB)
Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF
Completed in 01:58:09.875 (Average Transfer Rate: 73.95 kB/s)
Old 12-22-2014, 17:45   #2 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 186
Im doing same thing , hope I can recover my phone..
Firmware Version: 1.37, JTAG Manager Version: 1.56
Old 12-27-2014, 21:48   #3 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 186
problem solved. first erase full flash. then resurrection it. last flash it with original flash tool.
If all fails then change on/off switch.
Old 02-18-2016, 10:17   #4 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Samsung dead boot repair 100% done
The Following User Says Thank You to abishekkumar For This Useful Post:
Old 01-29-2017, 07:42   #5 (permalink)
Member: 2508646
Please Sir share s7562 riff jtag pinout detail.
The Following User Says Thank You to kccshafqat For This Useful Post:
Page generated in 0.13366 seconds with 8 queries
