12-29-2014, 07:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | samsung i8190 trying to boot repair give this error what to do?0x00000035 Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035 ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 0B Every 2 second it get connect n disconnect |
01-06-2015, 22:43 | #3 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi if you sure about soldered wires,this is eMMC damaged,Because if some pin connected to other place,eMMC can't detect Quote:
