05-12-2012, 09:06 | #3 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Check Riff-Tracker Riffbox Server :: Login Quote:
The Following User Says Thank You to BABAK NURI For This Useful Post: |
05-12-2012, 22:01 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
It's simple...Read full flash file from working phone ,Then write to another dead phone There are several reasons, Phone not power on after resurrect,DL Mode not Start ,hang on logo,restart, repair imei,and etc If Officiall Method For Reflash phone ,Can't Repair and Solve ,You Need Use Full Dump File For Solve Your Problem | |
05-13-2012, 12:34 | #6 (permalink) | |
Junior Member Join Date: May 2012
Member: 1756284 Status: Offline Thanks Meter: 4 | Quote:
If I do a full flash from from the working phone to the bad phone is there a chance this would repair the partition table? | |
05-14-2012, 07:46 | #7 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: Iran-Minab=((GSM Center))
Member: 1703463 Status: Offline Sonork: 100.1645756 Thanks Meter: 10 | Quote:
very nice information mr nuri | |
11-25-2013, 19:30 | #8 (permalink) |
Freak Poster Join Date: May 2005
Member: 146653 Status: Offline Sonork: 100.1649627 Thanks Meter: 21 | I have the same problem im new with riff box please anyone can help me to came back alive one I8320 it hangs at samsung logo.I have flashed 4 times with odin multi dowloader after PDA resurrection please help me to flash dump firmware |
11-26-2013, 09:54 | #9 (permalink) |
Member: 146653 Status: Offline Sonork: 100.1649627 Thanks Meter: 21 | Dumpin write stops at 25% please help me support Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung i8320 PDA V1.00] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 1.91V, TCK Frequency is 8 MHz Settings Code: 0x21010B00000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0058 (512MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK WARNING: Programming Error (0x24) at 0x000002160000. Attempting to Repeat. WARNING: Programming Error (0x24) at 0x000002160000 is Ignored. Last edited by adem; 11-26-2013 at 10:01. |
Nokia 5130 v5.71 dump needed Please!! | gsm13 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-16-2002 03:21 |
Nokia EEprom dumps needed... | Spalato | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-16-2000 10:26 |
Eprom Burner & Dump Utility | Bruyes | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-19-2000 10:57 |
Nokia 1611 dumps | Janos | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-01-1999 03:10 |
