03-11-2013, 19:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Inside of GsmhostinG
Member: 707582 Status: Offline Sonork: 100.1620432 Thanks Meter: 334 | samsung i9001 dead Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9001 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (M8G2FA, 0x0001CD000000 Bytes = 7.20 GB) Flashing the dead body...OK Resurrection complete! but cant come dounload mode phone didint power on |
04-22-2013, 11:47 | #2 (permalink) |
Junior Member Join Date: Apr 2013 Location: Saudi Arabia
Member: 1921649 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9001 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.63V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. solutions |
04-22-2013, 11:48 | #3 (permalink) |
Member: 1921649 Status: Offline Thanks Meter: 0 | [QUOTE=khan786000;9369158]Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9001 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.63V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. solution i9001 |
04-26-2013, 21:32 | #4 (permalink) |
Insane Poster Join Date: Feb 2012 Location: Portugal, Funchal
Member: 1720469 Status: Offline Thanks Meter: 12 | Same problem with I9001: Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.63V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
04-26-2013, 23:11 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi mpfa Are you Sure About bricked Phone ByWrong Firmware...? because usually is HW Problem So,Plz Contact me Via sonork, May i can Find Your Problem via remote...D: |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
04-27-2013, 16:11 | #6 (permalink) |
Member: 1720469 Status: Offline Thanks Meter: 12 | Hi Babak, Thank you, after reading your old post about you having this same problem, I realised that this is normally caused by HW fault in EMMC... I contacted phone owner again and he said he flashed a kernel (the same way he always did it before) it didn't gave any error but phone never turned on again... so I'm convinced that EMMC is dead now. BTW: "Using RTCK frequency gives the error I commented before and no memory chip detected, if I try using TCK frequency resurrector detects memory CHIP but still can't read or write to it..." Thank you for your help. |
