06-12-2013, 17:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | samsung i9100 dead boot repair problam pls any body help me....... first time use this box Uploaded with ImageShack.us |
06-12-2013, 18:04 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | RIFF BOX Advanced tutorial Quick repair of bricks RIFF BOX Advanced tutorial Quick repair of bricks http://forum.gsmhosting.com/vbb/f634...1/#post9496061 [SIZE="<font><font>6</font></font>"]You need to make sure that the attachment is correct[/SIZE] |
06-12-2013, 18:16 | #3 (permalink) | |
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Quote:
1 box 2 flax pinout 1 jig pinout totaly 4 item no more jig | |
06-12-2013, 22:11 | #4 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Earth
Member: 6884 Status: Offline Sonork: 100.1621477 Thanks Meter: 105 | you don't need molex connector, this is a solder problem, resolder your wires and check connection, USB cable and a good powering, i9100 work fine withe riff ps: use 8 mhz tck speed |
12-29-2013, 11:48 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: nepal,kathmandu,New Road
Member: 1139381 Status: Offline Sonork: 1593399 Thanks Meter: 225 | i9100 boot repair er0r Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. |
01-12-2014, 18:34 | #7 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: Romania Buzau Age: 54
Member: 14468 Status: Offline Thanks Meter: 50 | Quote:
What is the problem before repair with riff? best regards vali | |
